Question about Karcher 2500 PSI Pressure Washer
Honda excell 2500 psi NO WATER comes out of the pressure nozzel
Squeeze trigger, no water. Don't know what to do. Any suggestions?
  • messstat
    messstat May 11, 2010
    tell me more...have you checked the screen/inlet where you hook the garden hose up?
SOURCE: honda 2500 pressure washer,
The oil in the front of the washer turned a cream color...like it has water in it. Any comments?
Posted on Jun 02, 2008
  • 174 Answers
SOURCE: when I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Posted on Sep 24, 2009
  • 4090 Answers
SOURCE: karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Posted on Sep 26, 2009
  • 4 Answers
SOURCE: Power washer loses pressure. Engine runs fine.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Posted on Sep 30, 2009
  • 110 Answers
SOURCE: KOHLER HYDRO 13 When pressure washer engine is
first sheck the inlet screen where the garden hose attaches,if there is water flow then see if it has a manual pressure regulator, this will be a knurreled knob somewhere on the intake manifold of the pump, ifyou have one, turn it clockwise and see if there is a difference. If still no luck, disconnect the high pressure hose from the pump, start it and see if warer flows at that point, Your gun may be clogged or your hose may be delaminating on the inside and need to be replaced. If all this fails I suggest you bring it to an expert. These pumps can require special tools and expertise to repair internally
Posted on Nov 09, 2009
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
The engine will start but I'm not getting enough pressure when I press the the sprayer gun. Water is coming out but no pressure. Not sure what to do.
This can be caused by three different components. Either your unloader valve has failed, your valves have stuck open in the head of the pump or your water seals are worn. If you get an initial jolt of pressure when you squeeze the trigger then we know the problem lies in the unloader valve and you will need to purchase an unloader valve repair kit. If not you will more than likely have to replace the valves and seals in the pump.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 06, 2011 | Karcher 2500 PSI Pressure Washer
I just finished setting up my Homelite 2500 and turned it on. Once running to 30 seconds it let out a loud pop they scared the hell out fo me. I truned off imdeiately in fear of ruining the engine. Any...
Buck up now. You did good turning it off. Check the oil and water as described below and then fire it up again.
The power washer is your friend, but do NOT wash off your shoes while wearing them. Or rinse your dog or your hand >> it will blow a hole in aforementioned.
1) Your water has to be turned on before firing up the pressure washer. Simply squeeze gun trigger while starting engine. Do NOT wire the trigger closed to start or use power washer wand. That is a good way for the thing to break free and punch a hole in your pants.
2) You need oil in engine and in pump > engine oil comes about half way up dip stick > pump oil comes up to middle of viewing window on pump head.
That's all there is to know. I think your new engine had a growing pain, and things are fine.
Honda is a good engine. We ran our first Honda power washer for years until it fell off the trailer upside down and the chain kept it tied to the trailer until the gas tank was sanded off by the freeway after which it caught fire for a bit. You will have better luck.
Oct 06, 2010 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Power washer loses pressure. Engine runs fine. Taking the nozzel off, squeezing the trigger, and then putting the nozzel back on sometimes remedies the problem. How do I fix it? Thank you.
Sep 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2400 Psi Pressure Washer No gain of pressure
Sep 26, 2009 | Karcher 2500 PSI Pressure Washer
Low pressure
if this keeps happening repeatedly it sounds like you need a new seal kit put in it can be done easily enough by you or you can get a shop to do it , if you live in a cold winter climate be sure to winterize the washer every year or keep it somewhere where it wont freeze
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
358 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
