Question about LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray Disc Player - 1080p
Looking for the Dish Network remote code for the LG Bp330 Blu-ray player
Need remote code possibilities
Unable to reconnect to wi-fi
If you have not done so already, reset the player to factory settings and try again. If an ethernet cable connection is available, use it to get the best connection speed.
Dec 12, 2013 | LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray...
I HAVE A DISH NETWORK REMOTE THAT WILL NOT PROGRAM TO MY MODEL LCDVD199a
that remote only has about 50 possible codes built into it so it may just not have one that will work for the unit you want to program it to.
May 20, 2012 | Curtis Televison & Video
Remote code
yes you need to read the manual
Dec 31, 2011 | Aspire Digital AD-1000 DVD Player
Dish code
Hi Tim, my name is Mike Houston of DISH Network and I seeyour looking for the code for the Jasco-24911 remote. If you have the DISHNetwork remote you can connect it to the TV, VIP722K receiver, aVCR/DVD/Blu-ray player(s). We do not have the code here for that remote but Iwill send a link that will help with the setup for that remote; http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/24911-Manual-Eng-Spa.pdf
Nov 03, 2011 | Jasco 24911 Remote Control
I need a code to operate a Vizio Blu-ray player, VBR231, with Dish Network remote control. Thanks! ctelschow@msn.com
HERE ARE A FEW SUGGESTIONS TO LOCATE A SUITABLE CODE FOR YOUR
VIZIO BLU-RAY PLAYER, MODEL VBR231
  1. HITATCHI CODES ~ VIZIO CODES
    WHICH MEANS YOU SHOULD TRY HITACHI BLU-RAY PLAYER CODE(S) LISTED IN THE DISH NET RC MANUAL.
  2. FROM DISHSUPPORT.COM FORUM:
    Scott Greczkowski
    DISHSUPPORT STAFF
    hances are the 5.3 remote will not control that Blu-ray player. What will work however is a DISH Network 21.0 remote which not only has a better IR code database, but also is an IR learning remote. This means if the code is not in the remotes database you can teach it to learn all the functions of your Vizio Remote.The DISH 21.0 remote will also work fine with your 622/722.If you can't find a 21.0 remote then please PM me and I can tell you where you can order one. They may also be available from DISH Network directly.
*Configuring your devices with a "UNIVERSAL" Remote can sometimes be a stressful and frustrating experience. But it doesn't hafta be!*
Here are a few general
GUIDELINES TO UNIVERSAL REMOTE CODE SUCCESS
  • READ THE ENTIRE INSTRUCTION MANUAL THAT IS INCLUDED WITH YOUR UNIVERSAL REMOTE (OR DOWNLOAD ONE FROM THE VENDOR'S WEBSITE)
  • USE THE REMOTES "AUTO CODE SEARCH" FEATURE TO FIND A MATCH TO YOUR DEVICE (IF A DEVICE HAS ONLY PARTIAL FUNCTIONALITY e.g. CHANNEL +/- WORKS, BUT VOLUME +/- DOES NOT= CODE IS NOT THE BEST MATCH FOR YOUR DEVICE)
  • PRACTICE PROGRAMMING (AN)OTHER DEVICE(S) IN YOUR HOME TO MASTER THE PROCESS OF PROGRAMMING CODES WITH THEIR MATCHING DEVICES USING YOUR UNIVERSAL REMOTE CONTROL. TRUST ME, IT BUILDS CONFIDENCE, ASSURES THAT THE RIGHT PROCEDURE IS BEING FOLLOWED IN ORDER TO PROGRAM THE REMOTE, AND PROMOTES EXPLORATION OF THE "UNIVERSAL" ASPECT OF THE CONTROLLER.
Apr 02, 2011 | DISH Network Televison & Video
Looking for a code to use on my Dish Network (Universal) remote in order to operate my Emerson Model EWD2202 Combo VCR/DVD player
Hi my nameis Mike Houston of DISH Network and I was going over your post and see whereyou want the codes to program the DISH remote to the Emerson DVD/VCR. We do nothave the three digit codes to enter however we do have what we call a PowerScan and it will allow programming the remote to the Emerson player, I willsend a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Oct 31, 2010 | Emerson EWD2202 DVD Player/VCR
Need code for Sony BDP-S350 for a Dish Network 622 remote
We would be happy to help you with that. Here is a list of codes that should address your DISH Network remote to your Sony Blu-ray player: 629, 671, 868, 617, 501, and 768.
Press and hold the DVD/VCR button located on the top of the remote until all the mode buttons at the top of the remote light up, then release. Use the number buttons to enter one of the codes for your Sony Blu-ray player, then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Phillip Chang
DISH Network Customer Service Representative
Aug 01, 2010 | Sony BDP-S350 Blu-Ray Player
Remote Control access codes for Samsung BD-C5500 for use with Dish Network
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Samsung Blu-Ray Player: 506, 755, 807, 524, 534, and 591.
Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Samsung Blu-Ray Player, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times. To check that the code works try several differentfunctions on the remote to make sure it will properly operate your Blu-Ray Player. Keep in mind that some codes may not be compatible with it.If this is the case, please try the other codes listed for that device untilyou find one that is compatible with your equipment. We hope this helpsand thank you for being a valued DISH Network customer!
Phillip Chang
Jun 20, 2010 | Samsung BD-P2550 Blu-Ray Player
I have Dish Network and I can't find a Code for my LG RC797T so I can get it to play
I'm assuming you are referring to using the dish network remote to control your DVD/VCR unit. Use the instructions in your Dish Network manual, mine is on page 61, "Setting up using device code tables". Refer to the table of device codes in the back of the dish manual, pg 119, to look up your manufacturer. I used the DVD codes for LG as LG wasn't listed on DVD/VCR combo codes. Try each one until one works. I have the LG RC797T and the third code worked 824. Good luck!
Mar 31, 2010 | LG RC797T
LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray Disc Player - 1080p Logo
Top LG DIGITAL/AUDIO/VIDEO Televison & Video Experts
Electro Med Services...
Are you a LG DIGITAL/AUDIO/VIDEO Televison and Video Expert? Answer questions, earn points and help others
