Question about Dell Studio Xps 8100 Desktop Computer
Boot from disc
No hard drive
  • 24 Answers
Make sure you do not have a usb drive plugged into the computer. IF you need it left on the machine you will need to change the boot order in BIOS
Posted on Apr 14, 2016
Trying to put win 7 on hard drive says no bootable device insert boot disk and press any key put in boot disk and nothing
if you have win 7 on a disc and you want to put it on the hard drive , try this
on start up hold down alt+ delete to get into bios
change the boot up from hard drive to cd as primary start up boot up
put the disc in a cd and close it down
restart and the pc should then boot from the disc in the cd drive
you should be able also to simply put the disc in the cd, go to computer , click on the cd drive and run and that should put the win 7 on the hard drive
talk with a computer shop for other ideas as to how to do it if that doesn't work
Nov 29, 2016 | Cell Phones
Took acer 6733Z-4633 to tech. it wouldn't boot up. he said hard drive bad. he was able to save pictures and some files to USB. now I need to replace hard drive. sent for Acer recovery discs. if I cant...
when your laptop starts if it has F12 option push that and install your first disc and choose boot from cd player then follow instructions
if you dont have the F12 option when you puch the power button toggle the F2 key and go to boot menu and choose the cd player as first boot option and then hit F10 and save install boot disc and follow instructions
Aug 18, 2013 | Acer Computers & Internet
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
I have a HP G60-519wm, pn vm083ua. It gave me an error of no bootable drive and hard disc failure. I replaced hard drive, purchased new recovery discs from HP, and downloaded a boot disc. It still gives me...
try to open the cmos setting by pressing the f10 key then check if the hard drive you installed has been detected, if you can see it, go to boot option then change the 1st boot device to cd-rom drive then the 2nd boot device will be your hard drive then click esc to save the setting put your recovery disk on the cd-rom drive then reboot the unit if ask press any to boot from cd rom just press a key or simple tap any key on the keyboard, then follow instruction.
Aug 03, 2011 | Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
Laptop wont start up just says a disc read error has occured, press Ctrl+Alt+Del to restart but when I do this I just keep getting the same message
Two possibilities are involved. 1) The hare drive is not responding correctly. This could result from a loose cable (needs to be connected to the motherboard and the drive) or a damaged drive (either from damage to the disc or lost boot information).
2) A non-boot disc is being accessed in the boot sequence. This could be a CD/DVD in the optical drive, a floppy disc in that drive (older laptops) or a USB connected drive (either a thumb drive or a regular external disc).
The second issue is easy to solve, disconnect/remove any other media. Then try to boot. Alternatively, on most Windows machines, you can press F12 to choose the boot sequence. However, you need to press the button between the POST (power on self test) and the loading of Windows. For me, this can take several attempts.
For the first, the options depend on your skill/willingness to open the computer. One option is to use a Live CD (a bootable disc) to see the status of the hard drive. Use the F12 sequence if needed to boot from the disc. (The live cd could be a Windows Recovery/Install disc.)
To save files from the disc, you can either use a UNIX Live CD and an other drive (an external optical R/W drive or hard drive) or remove the disc completely and connect it to another computer. For this second option, use an IDE/SATA/USB dongle, a laptop hard drive enclosure or hard drive dock. The dock will work with a SATA drive; disc enclosures need to be selected to match the drive type (IDE or SATA). When you do the disc removal, you will see if the cables are loose. Be careful with static while opening the computer.
Then replace the drive with a new one, reformat and reinstall the OS or use the recovery disc to attempt to fix the boot problem.
I hope this helps.
Nov 26, 2010 | Computers & Internet
How do I restart my computer from the hard drive do I press ALT and F10 or can you tell me how to set up from a XP pro boot disc
if you want to boot setup from xp pro boot disc, you have to go first to the bios/cmos setup of your system, from there check the boot order, if you find that the first boot device is your hard drive change it, make your cd/dvd rom your first boot device and second your hard drive save the setting that you have made and restart your pc, before you restart insert the installation disc, then reboot, from there it will automatically boot in the xp pro set up disc
Dec 10, 2009 | NEC PowerMate ES SlimLine PC Desktop
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Toshiba Tecra Notebook
INstall the hard drive, if the hard drive came with a cd, put the cd in the drive and boot the laptop. When you see it say "boot from cd hit any key" do so and follow the prompts. This software will "initialize" the disc and install for the first time. Once the disc is "officially" installed take the hard drive disc out of the drive and replace it with Operating Disc. Reboot the machine and again look for the "Boot from CD Hit any Key" hit any key and let the system load windows. You only have to hit the key one time when it says "hit any key" even if during the windows install, the system may reboot but it still may need the disc in the drive, if you see the heading "boot from cd hit any key" dont hit any key any more....just let windows finish loading. When windows finally reboots, sometimes up to three times, then you can take the disc out of the drive or take it out if the operating system instructs you to. Good luck, ParrotHead PC Repair
Sep 04, 2009 | Toshiba Tecra 500CDT Notebook
Dell Studio Xps 8100 Desktop Computer Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
