Question about SMC (SMC7004AWBR) Router
SMC signal suddenly extremely weak
I've been using my SMC Barricade SMC7004AWBR at home for years.  A few days ago, the signal became extremely weak.  The network still shows up on the list of available networks, but I can no longer establish a wireless connection, even when I set my laptop next to the router.  My wireless card still works fine with other wireless networks.
Turning off my cordless telephone transmitter does not make any difference, and we have not brought any new electronics into the house recently.  Is it time to buy a new router?  I'd rather not do that right now.
  • elainewh Nov 12, 2007
    It works now after a firmware upgrade which completely reset the router software. If anyone else has this problem I would recommend logging into the router and doing a software reset.
    I should have rated rocker ramji's solution as "helpful" and I'm not sure how to change my rating.
    I reset the rating.
    Scholar:
  • 193 Answers
Login with ur router and change the channels>and use channel 11>1 and check with antena weather its straight looking the roof>and if its not works down grade or upgrade firm ware or use with out any security like wap or wep rate me solved if its help full thx
Posted on Oct 31, 2007
I want TO unistall SMC Networks SMC ADSL2 Barricade
click start all programs look for smc networks adsl 2 barricade program it might have its own unistaller
if you cant see it click start control panel uninstall or add remove program look for the smc network adsl2 barricade select it uninstall
hope this helps
Aug 14, 2012 | SMC Networks SMC ADSL2 Barricade
Router
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 16, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
Currently Connected to internet with to Telefonica through ethernet, and SMC Wireless router will not work. Router worked a few days ago, but now will not function either via ethernet or wireless. Our...
It appears the SMC router is faulty. The router is getting an IP address from the IPS because they can can PING your router and get a reply BUT the router's PPoE/DSL light is not on, it means it is not connecting with the ISP's WEB server and therefore you cannot get into the Internet.
Feb 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC Barricade SMC7004VWBR not found by Wifi toys
good day,
hope this link below will solve your problem.
routers
Feb 12, 2010 | SMC Barricade 7004VWBR Wireless Router
SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Nov 17, 2009 | SMC Barricade g SMC2804WBR Wireless Router
How do I make my SMC Barricade router go to a startpage
It sounds like what you want to do is have your web browser display a page when you open it... this is called setting your home page...
If you use MS Internet Explorer then
1) Go to the tools menu
2) Go to internet options
3) at the top set your home page
4) Press apply and ok
5) Now press the home button - this is the page Internet Explorer will display whenever you open it
IF this helped you then please help me and vote kindly.
Oct 09, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Intermitent signal strength
It is not unusual for the radio transmitters to fail in wireless routers after a year or two of use, especially if they're used in a location with poor ventilation or dust buildup. "Kaput" is probably a good term for it, but it would be worth finding someone with another laptop to try connecting through your router...just to verify that it's really a problem in the router and not in the wireless adapter in your computer.
Jan 11, 2008 | SMC Barricade 7004VWBR Wireless Router
SMC barricade g and timing out
just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
May 13, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
SMC (SMC7004AWBR) Router Logo
415 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
