Question about Magnum DeltaForce CB Radio
I need wiring diagram for d 104 to yaesu ft 101
I am trying to wire d 104 to a ft 101,can't find diagram
  • 396 Answers
SHIELD & BLACK -1 WHITE -2 RED - 3 This is what my Astatic book says for Ft101's. Good luck
Posted on Apr 02, 2014
2 Suggested Answers
  • 8 Answers
SOURCE: d-104 mike wiring
Go to cbtricks.com look up radio information go to magnum use the wiring set up for the 357.
Posted on Dec 14, 2009
I need a diagram for the lighting harness and list of what each wires controls. i also need a list of the colored wires to determine what wiring effects. my dashlights are out.
It may be helpful to know the make of the vehicle, year, model, engine????
Free Automotive Wiring Diagram for ALL Make & Model ...
www.wiring4cars.com/
Free Automotive Wiring Diagram in Full Color for ALL Cars, Trucks, Vans and ... who just need to trace down one circuit (i.e. radio wiring diagram, a/c circuit, ...
How To Wire Fog And Driving Lights Harness Wiring Diagram
www.accessconnect.com/fog_driving_lights_wiring.htm
Position the lamps at an equal distance from the center of the vehicle and as far apart as ... Note: This is a general wiring diagram for automotive applications.
Automotive Wiring 101 - OnAllCylinders
www.onallcylinders.com/.../wiring-101-basic-tips-tricks-tools-wiring-veh...
Dec 5, 2013 - Automotive Wiring 101: Basic Tips, Tricks & Tools for Wiring YourVehicle ... This chart can be used to determine proper wire gauge. First .... A factorywiring harness includes the necessary wiring for standard electrical ... The gauge youneed depends on the current draw of the accessory and the wire length ...
Jan 23, 2016 | Cars & Trucks
Astatic d104 wiring for Yaseu ham radio
( 9 Stand ) Astatic D104 to Yaesu FT 990
Pin 1 is White
Pin 2 is Red
Pin 7 is Shield/Blue combined
Aug 12, 2014 | Radio Communications
Need to couple Astatic D-104 mike to Yaesu FT-847 Radio
Check the wiring diagram online for both. It's a pretty simple connection setup.. Look at mods.dk for possible answers.
Feb 12, 2014 | Yaesu Radio Communications
No modulation on Yaesu 101 ZD
is the mic working properly ? in SSB you need a bit more mic gain
Feb 03, 2014 | Yaesu FT-101ZD Owners Manual
I would like to wire a Sure 526T to a Yaesu FT-101-ZD. I misspelled it in my previous post. Thank You.
Google is your friend. Google for the Shure 526T and there you will find a wiring diagram that you can download for free.
Jan 26, 2014 | Audio Players & Recorders
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Have intermatic t103 time switch, 240 v supply, clock motor not turning. what the correct wiring for the clock. 2 white wires...
Maybe-bad news.
The link below shows wiring for the T-104, T-103 and T-101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
For a 240V installation, the correct timer is the T-104, not the T-103
This is because the T-103 clock motor is 120V, and requires additional neutral wire on terminal A
The T-104 clock motor is 240V, and requires only the two hot wires and does not require a neutral.
I suggest you exchange timers and get the T-104
Or run another wire to nearby 120V receptacle and connect Terminal A to the white wires in nearby receptacles. This will give you the neutral that is needed for the clock.
In the absence of a Neutral wire, you can work-around by connecting ground wire to Terminal A >>> but this is NOT Code. You might use the ground wire as a temporary work-around until running additional neutral wire.
Oct 25, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Radio Communications Logo
274 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
