Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
When power to heater turned on r3 is displayed
When the power to heater turned on r3 is displayed but then the temperature reads 125, then 95, then stays at 80. The heater ignites initially but then shuts down
  • 4 Answers
Sounds like low water flow. Is there a manual bypass that may be open? If not, thermal regulator may be bad, or worst case scenario, heat exchanger is blocked due to imbalance of ph/alkalinity in pool water. Good luck.
Posted on Dec 04, 2009
When turning on power display reads 128 then error code r 13, after this it say's spa on but the temp reads 126 and the water temp is only about 68 so the heater never comes on.
This is not an error code. 128 r13 is the normal programming or software version for your model. you need to press the spa on button again, make sure the temp set point is higher then the actual water temperature
Mar 07, 2016 | Pentair Master Temp 400K BTU Natural Gas...
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
LO on Display
"LO" means lock out. This means that the heater has failed to fire, and will not attempt to do so again until it is turned off and back on.
Either the heater is getting no gas, the gas valve is not opening for any of several reasons, the signal to spark is not being sent to the ignitor, the ignitor has failed, or the heater is failing to detect that the burner has been lit. Best to get a tech on it.
Jan 26, 2014 | Sta Rite Sr400na Max E Therm Pool & Spa...
Display reading 109 degrees pool at 77 degrees so heater wont turn on
If the display is displaying what the heater thinks the water temperature is then there is likely a problem in the water temperature sensor or the board that reads it. I would be prepared to take the heater apart to measure values with a volt/ohm meter before calling the Sta Rite technical support number at 888-782-7483. They should be able to help you figure out what part is malfunctioning.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Sta Rite 200 Btu Propane Gas Heater...
Pool heater runs but the air coming out of the unit is cold.
R3 is not one of the actual error codes, but is part of the computer system. What you can try to do is reset the computer in the heater. First you will need to turn the heater off, then turn off the circuit breaker for the heater. Wait about 15 to 20 minutes then reverse the order, the circut breaker then the heater. Try and start the heater and watch the display panel.
If they R3 reappears, then the problem is the control board for the heater and it will need to be replaced.
Jul 02, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
426 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
