Question about Samsung Manual Inflate Blood Pressure Monitor
Blood pressure unit reads ERR 0 or ERR 3
What does the ERR codes mean
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
What is an error code 7?
On this model of SpO2 monitor from Medline, the "err 7" means the sensor has reached its end of life functionality... Basically it means it is time to buy another SpO2 monitor. I have a dozen of these in a rehab facility and have to swap them out every couple of years when I get this error code. I found this out a few years ago from Medline Support. This is why the warranty is 2 years (works out well that way, don't you think?). Hope that helps out some.. sorry for the bad news...Thanks!Stan Skaggs
Oct 13, 2014 | Medline HCSFSATSPORT: FingerSAT Sport...
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
Hello, I have an old model of blood Pressure monitor _Type 6054_ and I lost the notice. I have some error code that I don't understand. Please could you tell me what does mean this different error...
I have this problem too, after 9 years of reliable use. I can't find my manual either. From what I can see, the pressure release is going much faster than normal, too fast for the device to measure the BP. So i assume there is a problem with the air pressure relief valve, or there's a leak in the bladder system in the cuff. Looks like it's into the bin for my device.
Feb 04, 2011 | Braun Health & Beauty
My Walgreens Digital Blood Pressure Monitor pumps up to diastolic 118-122 then stops and deflates and the screen reads Err 2. Can you please tell me what the problem might be? Thank you.
Your Blood Pressure may be to high for the reading. Try to adjust the cuff and restart. Are you sure it is diastolic reading and not systolic?
Jan 13, 2011 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
Samsung Manual Inflate Blood Pressure Monitor Logo
44 people viewed this question
Top Samsung Health & Beauty Experts
Joe Ball
Joe Ball
Tom Chichester
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
