Question about HP LaserJet 3600n Printer
Can this printer take cardstock paper?
Will cardstock paper ruin the printer?
    Problem Solver:
  • 19 Answers
You can use cardstock through the manual feed only. It will wear the printer out 5X faster
Posted on Jun 19, 2009
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Looks like toner is not sealed to the paper.
the machine is only designed for 80gsm paper. you can change paper type through printer options in printer manager to card stock. it wil probably not work though as it is really only designed for 80gsm paper. the toner need to be heated to 200oC inorder to fuse to the paper cardstock absorbs less heat than normal paper.
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3600n Printer Logo
240 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
