Question about Samsung Manual Inflate Blood Pressure Monitor
Keeps reading ERR 0 -what does this mean
What does ERR-0 mean on my Samsung Blood Pressure Unit
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
I have put in two new batteries, but when I take my blood pressure it says "err"
Make sure that when you power it on, you let it sit for a minute before you test the pressure. The unit has to stabilize first.
Oct 21, 2013 | Wristech Blood Pressure Monitor
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
My Walgreens Digital Blood Pressure Monitor pumps up to diastolic 118-122 then stops and deflates and the screen reads Err 2. Can you please tell me what the problem might be? Thank you.
Your Blood Pressure may be to high for the reading. Try to adjust the cuff and restart. Are you sure it is diastolic reading and not systolic?
Jan 13, 2011 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
I have hd 1000s. keep ghetting ERR 1 when it begins inflating the cuff, stops and displays error message
My Omron only goes up to about 165 only takes about 1/2 the time it takes to get a reading from my Samsung. For my Samsung, I use a couple of velcro straps (can buy them at electronic dept's and they sold as wire-cord wraps), and I place them so they go across the seem of the arm band and keep it tight as the BP pressure goes over 215. This solution for me is the only way I can get this machine to perform consistently. It still runs about 10 higher than my Omron, but it is consistent - and now no longer gives me "Err-1" messages. BTW - I've got an order in for the "Advocate Wrist Blood Pressure Monitor" and I'll be happy to post how it works after I receive it.
Sep 28, 2010 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
Samsung Manual Inflate Blood Pressure Monitor Logo
43 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
