Question about Panasonic TC-P50G10 Plasma TV
Three blinks TNPH0793AC
Right turn signal doesn't always work beyond three flashes
The turn signals on new fords have two settings: three blinks, and continuous blinks. Small movement will set three blinks. Full movement will turn on continuous blinks. Please check, and if still bad you will need to see a mechanic.
Mar 25, 2015 | Ford Edge Cars & Trucks
Three blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 31, 2014 | Panasonic TC-P50G10 Plasma TV
Restore factory inputs
Especially if you have the three blinks error code:
No reset code, the three blinks shows the power supply failed to start correctly
Read more: Is there a reset code for my hd40-310 tv? when i turn it on, it power light blinks three times and the tv does not come on ' Answerbag http://www.answerbag.com/q_view/1817618#ixzz2FLPU13qu
3 blinks means a power supply issue which is not related to a reset which this set does not have.
Dec 17, 2012 | Thomson Televison & Video
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Three blinks - what does it mean
The safety limit inside the blower section has tripped.
Oct 31, 2008 | Goodman GMS90703BXA Heater
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Scandisk Cruzer micro 1.0 problem - three blinks, three blinks, etc
It means a problem in vista
I'll post if I find the solution , working on it right now
the good news is , it's not broken , it's just vista being a pain.
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
Panasonic TC-P50G10 Plasma TV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
