Question about IBM Wheelwriter 30 Typewriter
Only part of a letter appears when typed
Ibm wheelwriter 30 series II. new ribbon, but the only part of the letter appears. is there a pressure adjustment for how hard the keys hit?
  • IBM Master
  • 3,594 Answers
You can try code I to increase the impression but probably the print solenoid is gummy or the plastic solenoid is broken. We sell the caps with installation instructions for 20.00 includes freight. DickyO Cleveland Business Machines 216-241-0027
Posted on Jun 15, 2009
  • Dick O Reilly Jun 15, 2009
    After thought;
    Push down firmly in both sides of the platen (black rubber roll) they sometimes pop out just th tops will print.
    DickyO
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
Jun 30, 2011 | Lexmark Wheelwriter 30 Series II...
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
My IBM Wheelwriter III does not print the letters. I have replaced the ribbon but still no letters. Please help. Thanks.
rub your finger over the ribbon if no ink on fingers then your ribbon is dry little solution for old ribbons is cotton and little water over ribbon not too much
May 07, 2008 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 10 Series II
I assume you had the platen out and now it is not seated all the way in. Be sure the black latches are aligned with the side frames then push the platen FIRMLY down.
Oct 27, 2007 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 30 Typewriter Logo
142 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
