Question about Chevrolet 2004 Chevrolet Malibu LS
Car won't run
Car will not run after 30 minutes just replaCe the e.g.r valve
2 Suggested Answers
SOURCE: 97 lumina, 3.1. Starts runs smooth, drive for 30
I just recently have been fighting the same problem with the same make/model/year vehicle. For myself, I would drive off and on through the day and it would run fine. Then suddenly after a start it would run rough and die. I would have to wait 20 to 60 mins before it would start again. I had it checked and fuel pump was only putting out around 19 psi. It should be around 41 psi. Had fuel pump replaced and no more problems. Furthermore, now it runs so much better. It's funny how over time I didn't notice how the performance was slowly degrading. Unfortunaley fuel pumps for this car run around $300.
Posted on May 26, 2010
How to see if catalytic converter is plugged
while running look under and see if converter is cherry red thats a visual --go to rear and feel the exhaust coming out if restricted or clogging will feel lite flow also smell the rotten egg smell is alo an indicator ----but ----their are many reasons your car can act like that check fuel filter/fuel pump ---fuel pump relay [overheating] ---egr valve
Jul 06, 2016 | Cars & Trucks
2006 ford expedition will not start after driving, let it set 30 minutes and it will start right up and runs fine
Have pressure test run on your fuel pump. before fuel pumps fail they have intermittent issues like you described. Mine just did the same as yours and I replaced the fuel pump and fuel filter. she runs and starts like new.
Mar 24, 2015 | 2006 Ford Expedition
Uncommanded acceleration
Sounds like you don't know too much . Your best bet ,take it to the dealer . Replacing ECU needs to be reprogrammed . Inlet air control unit ???????? Throttle body . Electronic throttle body ! Have checked for DTC'S - diagnostic trouble codes . It's hard to fix something you don't know about .
Sep 06, 2017 | 2007 Chevrolet Optra 1.6
1988 buick regal stalls and restarts stalls and restarts
Sounds like a relay or coil failing.
To proceed you would need to find out if you are loosing spark to the plugs or fuel pressure to the injectors when it won't start.
Sep 22, 2012 | 1988 Buick Regal
Car won't start then exhaust fumes smell like varnish
Drop the tank remove all fuel replace the filter and fill with fresh gas
Sep 02, 2012 | 2003 Jeep Liberty
My camry car 1998 model stops always anytime I entered into water or rain after about 20 minutes it will work without any repair
sounds like the shroud that goes under the car is missing and water is getting up to the distributor. if it gets wet along with many of the other electrical connections the car won't run until they dry out
Jul 13, 2012 | 1998 Toyota Camry
93 Honda Accord won't start when engine is warm
Sounds like the pickup modual on distributor gets hot and malfunctions .after it warms up and it fails to start check for spark if no fire to spark plugs replace pickup module.
Sep 07, 2017 | Cars & Trucks
My car will run but when i cut it off it never cranks back up. It always takes at least a hour to crank back up..and it has became inconvenient to go to the store or anything.. What could this possibly be?
  • The first two things I think of is a back pressure valve or the started is getting hot and won't fire properly until it cools down.
  • Do you have a Check Engine Light on?
  • When you say "crank back up" do you mean after shutting the car down, upon trying to start, it does not crank at all? Or does it crank but will not turn over?
  • Have you checked the fuel pressure?
  • Have you checked for spark?
  • How old is that starter?
  • Do you have any further intel on the situation with your car that will help me help you better?
  • For instance, did this gradually happen. Like the car would start up and run and when shut off would bot start for 15 minutes and as time passes 30 minutes? Of did this just happen all at one out of the blue?
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Oct 06, 2011 | 1995 Volvo 960
Hi I have toyota tercel and check engine light is on with code po340. I allready changes senser, ecm,buy the light does not go what should i do.
disconnect the positive battery terminal for 30 minutes and reconnect it. This will reset the computer. If the light returns then you still have some more problems to work out.
Mar 01, 2011 | 1997 Toyota Tercel
Car won"t start. starter turns. Happened once before. started after 30-45min.
I would start by banging the bottom of the gas tank while you are cranking it over. If this causes it to start, replace the fuel pump. If it still doesn't start, there is a valve on the fuel rail on the top of the engine (you may have to remove plastic cover). Remove the plastic cap on the valve, and while you have someone cycle the ignition to the run position from the off position, depress the center tab on the valve and see if gas comes out. If it doesn't, replace the fuel pump. If it does, let me know and I will help you further. (note: replace fuel filer at same time.)
Oct 19, 2008 | 1999 Oldsmobile Bravada
Chevrolet 2004 Chevrolet Malibu LS Logo
10 people viewed this question
Top Chevrolet Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
xkikbxr
 steve
steve
Are you a Chevrolet Heating and Cooling Expert? Answer questions, earn points and help others
