Question about Eddie Bauer 31447 Booster Car Seat - Sage
How to remove seat cushion on car seat
Can't remove plastic part that strap slides thru
How do I remove the headrests in order to install seat covers?
    Remove the headrests. Then slide the cover over the seat back cushion (Photo 5). Push the bottom straps through the gap and into the buckles just like you did on the bottom cushion (refer to Photo 3). Reconnect the bib panel and pull down on the rear portion of the seat back cover to remove wrinkles.
    Spruce up Your Car: How to Install Seat Covers ' The Family ...
Oct 04, 2014 | 2012 Chrysler 200 Touring Convertible 2.4L...
How do I remove the rear passenger seat in an 03 Hyundai Santa Fe?
there bolts that hold it in that are between the lower cushion and back cushion by kneeling on it you can see them usually a 10mm bolt head .
Sep 26, 2014 | 2003 Hyundai Santa Fe
Remove rear bolster cushion from s type jag
pull up the front of cushion on either side in turn, put your fingers under the front edge about 10 inches from outer edge you will feel a little plastic lever, you slide to one side, repeat for other side you can then remove seat cushion.
Feb 23, 2014 | 2005 Jaguar S-Type
How do I remove the seat on a 2002 Supe Dyna Glide?
Remove the screw from the rear seat bracket.
Slide seat to the rear of the motorcycle and lift the seat. There is a tab that secures the seat to the frame under the front of the seat.
The strap can remain in place and slid to the lower front section of the seat. The seat can be slid thru the strap.
Dec 05, 2010 | 2006 Harley Davidson FXDCI Dyna Super...
How do you remove the rear seat in a 2002 Mercedes C240?
please check below the rear seat you can see small plastic cover have fitted near seat it's same color of your interior carefully remove that plastic covers without braking locks then you can see bolt for remove rear seat cushion remove bolts and slide the cushion towards front.
Sep 14, 2010 | 2007 Mercedes-Benz C230 Sedan
Washing Carseat Fabric
You may have solved this problem already, but I had a similiar situation. If you can remove the round hard plastic fasteners that the straps pass through, it really is not too difficult to take the pad off. They are just clips that push against the hard plastic back of the seat to hold the straps in place. To remove them, I just took a flat head screw driver and placed it against the long side of the fastener and pushed up and toward the center of the fastener. I did this for both sides of the fastener and it popped right out. The straps then just unhook from the back and thread through to the front. Make sure to note how the straps are placed so that they can be replaced correctly. The pad washed up very nicely for me. I used warm water and regular detergent. I let it dry in the sun. Hope that this helps.
Jun 10, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
2001 isuzu rodeo rear seat
Just Pull the straps that lie in between the seats. Not the seat belts but there are two straps. Pull them, pull the seat up from toward the seat back, pull out the headrests and lower the seat back. The seat cushion should/ bench seat should lie up against thge two front seats.
Jun 06, 2009 | 2001 Isuzu Rodeo
Hai i would like to know how to fold the back car seat to increase cargo space in hyundai santa fe 2003
The rear seats have a pull strap located between the bottom cushion and the backrest of the rear seats used to disengage a lock to lift up the bottom cushion. The pull straps will only stick out an inch or so, or they might have fallen down between the seats and then you wont see them. Before you can lower the backrest of the rear seats, the bottom cushions have to be lifted up and forward out of the way so that the backrest may lie down flat. If your pull straps are not visible between the bottom cushion and the backrest, you may have to stick your hand between the cushions and feel for the straps. Once you find the straps, pull upward on the while lifting on the bottom cushion where the pull strap is located and the seat should tilt forward. Once you have manged to do this, the lever for the backrest is located on the top of the backrest. Just slide the lever and tilt the backrest to the desired position.
Apr 13, 2009 | 2003 Hyundai Santa Fe
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
Help
need to adjust straps
Feb 12, 2008 | Evenflo Cozy Carry 5
Eddie Bauer 31447 Booster Car Seat - Sage Logo
27 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
