Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Electric garage door does not always close
It is a chamberlain brand. Sometimes it won't close. I had a technician out and he said the motor was good. Almost always will open, but, won't close unless I hold the button down.
  • 3,382 Answers
Check the alignment of the photo cells. If they are out of alignment, even a little bit it will behave like you describe.
Posted on Apr 29, 2014
  • 118 Answers
SOURCE: My Liftmaster garage door opener will not close
You have a problem with the safety eyes. Make sure both eyes have a lit Led light, if not realign sensors
Posted on May 15, 2009
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Posted on Jun 19, 2009
  • 34 Answers
SOURCE: Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Posted on Oct 10, 2009
swolfinor
  • 504 Answers
SOURCE: Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: door only closes when button is held down at main ...
99% SURE IT IS THE SAFETY EYES - ALIGNMENT, WIRING, OR BAD EYES
HOPE THIS HELPS
Posted on May 26, 2010
swolfinor
  • 504 Answers
SOURCE: Garage door won't close unless
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
Posted on Oct 22, 2010
Garage door won't go down all the way and then reverses to open
Check that the wheels and bearings are turning freely and that the door is not cocking to one side when closing. If the wheels are catching because of bad bearings, because the tracks are out of true or because the door is not staying straight in the tracks, the motor thinks that the door is hitting a car or a person and reverses. One thing to try: disengage the motor and try moving the door through the full traverse. Most automatic doors have a pull-cord that disengages the door from the motor. CAUTION: You may need a friend to help with the door, because it could be surprisingly heavy,.
May 01, 2017 | Chamberlain 3/4-HP Whisper Drive Plus...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened fine but now when I try to close it, all I hear is a buzzing sound for 3 sec., light comes on but door won't go down.
Your trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to relieve the strain on the chain and then run the opener until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
My nephew kept opening and closing my garage door, now the door won't open with the opener and I can lift it by hand. I tried pulling the cord to move it back to electric but it won't work... any...
The motor has a thermal protector that will cause the motor to quit when it gets hot. If you let it cool off it will automatically reset and should work again.
Jun 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door always opens, intermittant stopping when the door is closing. Sometimes it closes all the way, other times it stops repeatedly and you must press the close button many times to get the door to close....
Sorry to say,u should of replaced the whole control box.This is not a sensors problems,it the control box problems.U know basic electronic's and soldering?Take the control box aparts,check for these bad capacitors leakages,these capacitors alway have the top of it bulges or puff up.These capacitors not giving it max power that why it work sometimes,sometimes don't.Replaced these leakage capacitors,ur power should return yo normal.
May 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
59 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
