Question about Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda
Honda crv 1996 radio wires
Colour code for radio harness
Need radio code for 02 honda crv, serial #13028929
The reset code for the factory installed radio is on a sticker in the glove box. The sticker has 2 set of numbers. The number set with 5 digits is the reset code for your factory installed radio.
Jul 09, 2010 | 2002 Honda CR-V
MY 2007 HONDA CRV CAR RADIO LOCKED AND IS ASKING FOR CODE
inside glove box there should be a sticker with the radio serial number and code. if that has been removed then you could try the honda owners site. you'll need the vin # and some other info
I was able to get the code recently for my 2010 CR-V
Jan 08, 2010 | 2007 Honda CR-V
Nissan vanette wiring diagram for radio or colour codes
Nissan Radio Wire Harnesses
(clic for zoom)
More details and Nissan models can find it HERE
I hope helps with this (remember rated this help) Good luck.
Dec 22, 2009 | 1996 Nissan Sentra
Radio Code for unlock 1999 honda CRV car
HONDA codes are not readily available from anywhere on the Internet apart from here
https://radio-navicode.honda.com
You will have to quote the car`s VIN number + other details.
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Sep 30, 2009 | Car Audio & Video
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
Wireing in car stereo accord 2006
good morning and welcome to fixya.
are you installing the factory radio or an aftermarket radio? you can purchase a wire harness for this vehicle that will plug into the factory chassis harness without cutting the harness connector. if your connector is missing the wires in the aftermarket harness are color coded the same as the wires on the factory side. check best buy or crutchfield.com those guys at crutchfield are really great. good luck and let me know if i can help anymore. thank you
please don't forget to rate this solution
Mar 13, 2009 | 2006 Honda Accord
Car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
Dec 20, 2008 | 1993 Nissan Maxima
Radio code for Honda CRV 1999
If the radio has not been changed in the past, then I am almost certain that your local Honda dealaship can help but as always they may charge you. There are auto centres that are equipt to change the radio code and they do charge.
Nov 30, 2008 | 1999 Honda CR-V
CODE RADIO
call your local honda dealer with all of your car details ,make,model,registration plate number ,colour,and owner details and they should be able to give you the code over the phone free of charge,,hope that helps,,goodluck.
Nov 27, 2008 | Car Audio & Video
Car stereo
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
Aug 17, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda Logo
16 people viewed this question
Top Custron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Custron Audio Player and Recorder Expert? Answer questions, earn points and help others
