Need to write numeric numbers as time of day
Clock
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
I have numerous times in last 2 days how do I get an answer?. Here goes again . How do I reset time on sony dream machine serial no.4841857
1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
  • 2 Press "Clock" if you are not in the U.K. and need to set the time manually. Hold it for two seconds.
  • 3 Press the + and - buttons until the year is set correctly.
  • 4 Press "Clock" once you've set the year, and repeat this process for the day, hour and minute.
  • 5 Slide the "Alarm Mode" toggle to either "Radio" or "Buzzer," depending on your personal preference.
  • 6 Slide the "Alarm Time Set" toggle to either the + or - side until you've reached the time you want your alarm to go off at. Hold it down to adjust in 10-minute increments
  • Read more: http://www.ehow.com/how_7396985_instructions-sony-icf_c218-clock-radio.html#ixzz2jjJEJSA3
    Nov 05, 2013 | Home
    Want to change keyboard clock
    To adjust the LCD's time and date:
    1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
    2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
    3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
    4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
    5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
    6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
    7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
    Sep 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
    Setting clock and date on logitech mx3200 wireless keyboard - need instructions
    The time and date on the LCD should now be displayed properly.
    Aug 18, 2009 | Logitech Computers & Internet
    Anne Klein chronograph watch
    The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
    Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
    IN 120 base keeps flashing CL
    This is due to the base unit losing power and needs the clock resetting.
    The handsets retain their clocks under battery power so this is a little misleading.
    To reset the base unit clock:
    - press the OK key
    - press the 'down' arrow twice until "DATE/TIME" is displayed.
    - press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
    - The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
    - The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
    - The handset then beeps and displays "SAVED".
    - Press the "C" button and replace the handset on the base unit.
    The base unit should now stop flashing "CL".
    Jul 09, 2008 | Lands Phones
    Need instructions for change time on Logitech MX3200 wireless keyboard
    Mar 17, 2008 | Logitech Wireless Access Duo Optical...
    14 people viewed this question
    jasbo
    jasbo
