Question about Revell 125 2002 Chevy Camaro Ss 35th Anniv Edition
Cranks over slowly and then dies and lights gets drawn down
Battery charged
    Top Expert:
  • Revell Master
  • 3,141 Answers
If the battery checks out, it's likrly the solenoid.
Posted on Jul 16, 2016
2007 Volkswagen golf gti.
get one of those online manuals. You'll not have to wait for others to answer, or rely on mechanics and all. Plus i know a website that sells very cheap but very very good manuals online
Try this website here,
reliable-store com
also try manualslife both are good for this
Jan 30, 2018 | Volkswagen Golf Cars & Trucks
Hyundai Elantra keeps dying despite my electronics being off.
Does the car crank slowly, or the starter clicks when you attempt to start it? If the alternator or voltage regulator is bad, the battery would continue to lose energy and appear to be bad. Alternators need to be fed voltage since they don't have magnets to excite the windings. On my Volvo, sometimes the indicator lights don't come on when I turn the ignition on, before actually cranking the engine. When this happens, I know from experience that the battery won't charge. Do you get any dash lights showing a problem?
You can check the voltage at the battery when the engine is running; it should be well over 12 volts if charging.
If a trunk, glove compartment or interior light is on, that can run the battery down too.
Nov 02, 2015 | 2004 Hyundai Elantra
Is the battery need to change
A dying battery will crank the engine slowly, or sometimes you just hear a click. Charging such a battery may not fix things as it will not hold a charge overnight.
There is a crude test: turn on your headlamps and watch them while someone cranks the engine. If they dim right down before the engine fires, the battery is weak.
Any battery shop can do a discharge test and give you an exact answer.
Aug 26, 2015 | Vehicle Parts & Accessories
I was driving my 2001 sukuie down thestree, it just died like you yurned the key off and it would not restart, hauled it home and now need to find the problem, it has pleanty of fuel.the lights in the...
wont CRANK or CRANKS Fast but will not start , which is it?
the fuses blew or the battery is dead (discharged)
battery voltage is 12.6vdc rested, if not and is lower, its discharged.
did warning lights come on before the STALL? (died is stall)
if yes, and the charge lamp came on, and was ignored this is normal
for the battery to die. with alternator dead.
try jumper cable starts yet? that be next after fuses. and battery volts. (no cranking)
if it cranks fast, still fuses. check. then check for spark if not a diesel. some GV have Diesels, (3 kinds too)
Jun 18, 2014 | 2006 Suzuki Grand Vitara
Battery spark at terminals
ok, first check you battery is actually maintain a good charge while your cranking the engine. If voltage drops below 10v your battery (Although appears fine while sitting) May not be any good when current is being drawn from it.
Its quite normal to see a small spark when connecting up a battery with voltage in it. If there were a short at the battery terminals you'd be blowing 30amp main fuse all day long.
Next if you replaced starter motor was it a new one?? If not then you may want to check the brushes inside are not worn away. Before doing that though try running a direct 12v straight into the starter motor to see if it cranks bike correctly.
Jan 15, 2018 | 2000 Honda VTR 1000 F Firestorm
2000 pathfinder battery draining
Sounds like your alternator is doing nothing-the car is running only off the battery. Have your charging system checked-does your battery light stay lit? If that bulb is burnt out, that may be why the charging system is not working. On some charging systems, that bulb is crucial for the alternator to work.
Engine off, a fully charged battery should measure 12.5 volts with a voltmeter. Engine idling, and the voltmeter at the same battery should be showing about 13.5 volts. This tells you the charging system is working.
May 13, 2017 | 2000 Nissan Pathfinder
Dies while driving
First off, add a new ground wire from the engine to the body just for the hell of it. Now clean all the battery cable connetors aat all point and add WD40 afterwards. Also check connectors from dash panel to engine circuits. This is real suspect. WD 40 them also
May 07, 2009 | Chevrolet S 10 Cars & Trucks
2006 Tuscon Battery Dies while Parked--randomly
It is the Alternator. The Battery will Charge But drains while Driving. The Alternator is not Recharging the Battery while the Motor is Running.
Jan 21, 2009 | 2006 Hyundai Tucson
Revell 125 2002 Chevy Camaro Ss 35th Anniv Edition Logo
69 people viewed this question
Top Revell Toys Experts
Vernon Taylor
DROPNDEAL
DROPNDEAL
rhodesworks
Are you a Revell Toy Expert? Answer questions, earn points and help others
