My TV will not come back on.
I have replaced the DLP Lamp and also the lamp ballast.
When I turn the unit on it will make a sound like R2D2 in STars Wars and then it sound like it is trying to turn on put I get no picture or sound at all.
When I look at the back of the unit I can see two little green lights that turn on. Should there be more?
What should I do next?
Thanks Dan
It sounds like the ballast that powers your lamp is bad. What are the indicator lights on the front of the tv doing?
Posted on Oct 31, 2007
you can try making sense of the troubleshooting below otherwise give an email address and i will send the file
No.
Item
Description
Remarks
When the
Timer, Lamp,
and Abnormal
Temperature
LED indicators
flicker simulta-
neously.
Ballast CN2 terminal
Ballast CN1 terminal
*When measuring voltage,
make sure to measure the
voltage between the two
terminals.
1. If the 3 LED indicators flicker from the time the set is
turned on, it means:
1) The CN106 connector on the DMD board is not inserted
properly.
2) The MDR cable that connects the DIGITAL board to the
DMD board is not connected properly.
3) If the lamp does not turn on even after turning it on three
times, by powering off/on 15 second intervals:
! The B+ 380V power is not supplied to the ballast
(The cable is not connected properly between the power
and the ballast.)
@ The cable connected to the CN110 terminal on the
DMD board and the CN2 terminal on the ballast is short-
circuited or not connected.
# The lamp does not turn on because 5V has not been
supplied to blue pin #1 on the CN2 terminal of the
ballast.
$ 5V is supplied to the CN2 terminal on the ballast but the
lamp does not turn on because the ballast has a failure.
(If the lamp is replaced and 5V is supplied normally to
the CN2 terminal, suspect a ballast failure if the lamp still
does not turn on.)
% The ballast is normal but the lamp doest not turn on.
(When 5V is supplied to CN2 and 385V to CN1, but the
lamp does not turn on, try replacing the lamp. If it turns
on, that means it was a lamp failure.)
4) The color wheel engaged to the engine does not operate,
or the connector which indicates the operation of the
color wheel is not connected properly, and therefore
does not allow the lamp to turn on. The cause can be
determined when the set still does not turn on after
attempting to turn it on three times.
5) Another digital board or the DMD board has a failure.
Conclusively, if the three LED indicators flicker, first
check the above five items, then check the various
connector connections, and then suspect a failure of the
lamp or the ballast.
CN106
MDR cable
Color wheel
connector
Color wheel index connector
Lamp connector
Probably a bad or broken color wheel.Very common with Samsung DLP.If the wheel doesn't start to turn,the lamp ballast won't fire the lamp.
Posted on Jan 10, 2009
BLACK OUT NO PICTURE NO SOUND
Posted on Oct 18, 2009
I was having flickering, and then blackout, overeat and lamp led's blinking. I figured it was all dusty inside. I pulled the back cover, removed the screws holding the light housing in. (3) brass screws are visible through smaller door opening, top left screw holds light box, screws along bottom holds ballast board in, took top left screw out, pulled light box out, had plug on bottom side, very nice. Then I lifted the board out, it has (2) plugs to it, 1 big two wire plug outside edge of board, I removed this plug to pull out the ballast board, removed visable dust, then replaced board, visually no burned connections or resistors, tighhtened screws to secure board, reversed all disssembly actions in order above, dusting as I went. All good so far put the cover back on so the blue switch behind it is in the down pos. helpful info for testing, power on w/small door removed, (trip switch to down position gently) will allow you to test before final closing !!!!DANGEROUS!!!! but useful for the trouble shooting I could have avoided later see why. Do at your own risk, I was fine but I only touched what i knew wasnt live, screws and plastic cover to lightbulb box. I did final closing and tried it out. NOTHING, Oh my what have I done, I took a 20 min. break and gathered my thoughts. I went back in, I got more light on the area I was in, the other smaller plug w/wires I didn't detail earlier now comes into play, it's a 5 wire mini white clip plug 4-white, 1 blue at end of clip, it was still plugged in on the ballast end but on the opposite end of the wire, unplugged. So small I could'nt find recepticle for it, looked in the area of where it was laying (it ran up to the top of a silver cover w/ holes allover) Almost all the way to the right on top of the holed panel was a plug. I took apart the fan assembly (after that there are three spring loaded screws, holding cooling fins to the panel, very light tension, nothing pops out, but dont lose the springs when you pull the screws out) to remove that panel because the wire group wasn't long and had a clear plastic sleeve over it and I knew it went somwhere, tilted the holed panel toward me and saw the plug (very sneaky), plugged it in (it only goes one way) and reassembled the fan assembly which may not have needed to be disassembled, but made it easier I'm sure. I didn't take the light or ballast out this time, so it was easier. Now the trick from earlier, I plugged it in and gently engaged the small blue switch to the down position. Asked assistant to power on while I held the switch down to check airflow, light coming on, ballast firing, all good ,everything worked and great. Powered down at the main switch, waited about 1 1/2 minutes until fan stopped, reinstalled cover, powered back up, good as new. maybe that plug became somehow dislodged on yours, unknowingly as mine did because of the similar symptoms no picture, no sound and repeated attempts to fire. I was extremely careful it still was not enough. It fixed it though. Scoundrel to savior all in the same day, nice. Take a look to see if that wire was removed some how and try to plug it back in. If not, sorry, I was so happy I wanted to help someone else save some money if possible. I repeat, I do not condone the removal of the cover as pertaining to warranty concerns or safety. I did, but I may have been the lucky or crazy one. It worked for me and I would do it again and better next time.
Posted on Nov 15, 2007
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
on Mar 25, 2010 | Televison & Video
Dec 09, 2015 | Televison & Video
Apr 10, 2013 | Televison & Video
Mar 31, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Aug 13, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Mar 09, 2016 | Samsung DLP HL-P5663W 56" TV
3,773 people viewed this question
The lights are blinking.
But I also do in a new lamp ballast already.
Thanks Dan
I have a 61" samsung DLP tv one of the earlier models. I chaged the lamp about one year ago. I have a problem when I turn on the tv, it sounds like the tv is trying to come on but i get no picture and the power switch keeps on turning on and off.
I am having the same problem with a 42 inch DLP I replaced the lamp but still no picture and makes the same noises as Danny is describing??
I have a 617 and it just started to do the same thing no pix no sound on and off cycling
Ok, I have a simular issue. I have pic but no sound. Got a new bulb and housing but it didn't solve the problem. TV also cycles on and off every 20 seconds. What do I change now? The ballast?
