Question about Bosch 800 DLX Series SHX68TL5UC Fully Integrated Dishwasher with 16 Place Setting Capacity, 6 Wash Cycles, 5 Options, Duo-Flex Silverware Basket, Flexible Third Rack, 44 dBA and SpeedPerfect Option
Bosch diswasher display reads "Watertap E:22"
Started dishwasher as usual in automatic cycle but was gone from home while it was running. I opened the door to unload clean dishes and display read "Watertap" in red with E:22 on timer. Suggestions?
COXY
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
SOURCE: Bosch dishwasher
Hello guest. seems you have a leak in the base. Looks as though motor is washing dishes but actually its the drain pump thats been activated which doesnt allow the timer to proceed forward.
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Posted on Oct 03, 2008
SOURCE: Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
Posted on Dec 31, 2008
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
Watertap message on Bosch dishwasher
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
Nov 16, 2013 | Bosch Dishwashers
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHU5315UC dishwasher doesn't end cycle
make sure 120 degree water enters the diswasher
Feb 08, 2010 | Bosch SHU5316UC Dishwasher
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 800 DLX Series SHX68TL5UC Fully Integrated Dishwasher with 16 Place Setting Capacity, 6 Wash Cycles, 5 Options, Duo-Flex Silverware Basket, Flexible Third Rack, 44 dBA and SpeedPerfect Option Logo
618 people viewed this question
Top Bosch Home Experts
Donni Steen
Tom Chichester
Are you a Bosch Home Expert? Answer questions, earn points and help others
