Question about General Electric GSD3360DSS GER Built-In Dishwasher
GSD3360DSS Dial won't turn, soap dispenser won't close
Where does the rinsing agent go?
On most dishwashers it is next to the soap dispenser, it will probably be a cap you turn to remove, there may be a dial as well to regulate the amount dispensed during the cycle.
Dec 13, 2014 | Dishwashers
Dishwasher soap dispenser
If the dishwasher's turn dial isn't on off the door will not shut. Try turning the dial to off on the front of the washer.
May 15, 2013 | Dishwashers
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 10, 2011 | GE Dishwashers
Soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
Sep 04, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Jan 02, 2008 | GE Nautilus 24" Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
General Electric GSD3360DSS GER Built-In Dishwasher Logo
18 people viewed this question
Top General Electric Dishwashers Experts
Tom
gbob59
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
