Question about Pool & Spa
Laars lx400 blower does not come on
Gas is on, control panel seems to be working, when turned on nothing happens, no blower, after 2 or so minutes high limit switch error comes on. I have checked both switches and and both are closed.
  • 1 more comment
  • John Seifrick
    John Seifrick Mar 31, 2014
    Both limit switches test to be closed, zero impedance. My understanding is that the blower should come on first, then ignition. The blower does not come on. . . nor is there ignition which I would not expect since the blower is not on. Seems strange that the limit switch error occurs over 2 minutes later when the heater is not heating.
  • John Seifrick
    I need some advise on how to test the blower circuit as a first step instead of replacing stuff as a diagnostic.
  • John Seifrick
    Schematic indicates a "manual reset high limit switch" and a "fusible link". Any clue as to where these are located?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Check filters or pressure switch sounds like safety switch isnt working
Posted on May 08, 2014
3 Suggested Answers
  • 22 Answers
SOURCE: High Limit Swtiich message
The high limit switch is one part of a safety loop circuit that must work before a heater can fire. It's purpose is to ensure tha tthe heater will shut off in the event of a thermostat failure or if the internal core gets too hot due to a lack of water flow. If the switch is failing, it needs replaced. There are 2 so you can replace both or make an attempt to determine which one is bad. It is best to replace the pair.
Posted on Dec 21, 2008
jharwell668
  • 640 Answers
SOURCE: Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
Posted on Aug 12, 2010
Tip
Laars LX400 Manual Download
Laars LX400 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX400 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX400 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Laars LT250 pool heater. I went to start it the other day and pushed the on/off botton and the light went on. I turned up the temp setting, but the light did not begin to flash and the heater...
I have repaired one like this and it is fairly complicated. I ended up replacing the control panel. That doesn't mean that is what will fix your heater. If you have a volt/ohm meter and call Laars technical support number they might be able to help you figure out what to do. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Teledyne Laars Laars Lx Nat Gas Pool...
My LX400 Laars hearter has started to vibrate loudly when running. I suspect its the blower assembly. How does the top rempve from the heater so I can get to the blower and check it? I see no screws or...
Not the blower! It's the Thermal Bypass located where the inlet and outlet pipe enter the heater. There is a thermal sensitive spring assister valve in there. It needs to be replaced. Probably due to bad water chemistry!
Mar 27, 2011 | Jandy Laars Lx 400,000 Btu Heater
My control panel/board on the LX400 is always getting fried. When I replace it with a new one, same thing happens - the blower turns on and runs continuously even if the heater isn't running. Any...
Check that your heater isn't wired to the line side of the timer. It should be wired on the load side, NOT the line side. Problematic at best to have your heater powered all the time, at worst deadly to the heater should your various pressure/temp sensors fail and the heater fire up when the pump isn't on.
May 26, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean
Temp control failure (thermostat) high limit is safety to prevent over heat.
Jul 26, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
