Question about Transmission & Drivetrain for Chevrolet HHR Panel LT New Cars
Torque spec th350 transmission
What is the torque
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
I think its 18 ft lbs not sure
Posted on Sep 09, 2014
Why dont i have no forward & no reverse in my th350 transmission i just put it in my 82 chev c10
Hi Loren, My name is Randy and I'm going to try and help you with your problem, But I will need some more information from you. First did you by chance not bolt the torque converter to the flexplate or flywheel? Next Linkage is it installed on the trans and working properly. And what was the reason for pulling the transmission in the first place? Please get back to me maybe we can get your problem solved Thanks Randy.
Dec 23, 2015 | 1983 Chevrolet C1500
I have a 1987 G20 Van 305 automatic,turbo 400 tranny. I get going the tranny shifts fine til I hit 50mph then it starts to slip , I have done a filter and fluid change , had to replace the vacuum line...
It could be failing clutch packs or a failing torque converter. I had a TH350 that whined after upshifting to 3rd, then it quit. For me it was the torque converter. It took out the entire transmission, including the oil pump.
Nov 13, 2014 | Cars & Trucks
I need a diagram for GM th350 transmission
Go to dealer and have them look up part, take photo of drawing, and say you will be back to buy part.
Sep 27, 2014 | B&M Performance B&M, TransKit, GM TH350,...
WILL A TH350 TRANSMISSION WORK ON AN 89 SUBURBAN WITH A 700R4
It will but you will lose Overdrive and that will cost you a lot of gas money in a Suburban. You will have to rewire the neutral safety switch as the TH350 only has 2 wires.
Oct 25, 2013 | 1989 Chevrolet Suburban
I have a 1985 Gmc Sierra with a TH350 transmission and it shifts well but the torque converter doesn't lock in or pull the motor down like it should. I have it hook up to the green and yellow wire (ma
You really should get an automobile service manual for your truck. Haynes makes a good one and it is available at your auto parts store. Don't mess with an auto transmission without a guide book...it is cheaper than replacing the transmission!
Jan 11, 2013 | Cars & Trucks
Need to know what other transmissions can bolt up to a 70 olds cutlass 350?
Tou can use any olds pont or buick 350 out of an earlier car that had a V-8. you can also install a 400 using a crossmember from a car that had a200r4 tranny in it. providing your car has a frame mount welded in on the left frame rail. otherwise you have to relocate the tranny mount on the exsisting crossmember.
I have an 81 buick that now has a455 olds with a th400 in it, I asol have an 80 cutlass with a 403 and th350 from a 78 pont wagon in it
the trick is to use the non lock-up version of the TH350.
Hope this helps
May 04, 2009 | 1983 Oldsmobile Cutlass Supreme
Chevy TH350 trans problem
if you just had it rebuilt should ba a warranty if is was im sure you wouldnt be on here asking so did you install new torque converter when the trans was rebuilt? check the trans filter not clogged how long did it run after the rebuild or did you install it yourself after the rebuild and it doesnt work ? let me just say the torque converter should always be replaced with the transmission new or rebuilt and when the transmission is being installed you have to make absolutely sure the converter is all the way back on the trans if not you will damage the front pump on trans and would need to replace it .
Mar 23, 2009 | 1985 Chevrolet Nova
Transmission toque specs
The spec is 12 ft lbs of torque. Use a an even pattern when you tighten the bolts, this assures the gasket will not be damaged and create another leak.
Jul 27, 2008 | 2003 Dodge Stratus
Transmission & Drivetrain for Chevrolet HHR Panel LT New Cars Logo
42 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
