Question about Concord Fans PB-1256-EMN GRANDEVILLE Brazillian Bronze Ceiling
Fan stops working
Fan no longer works
Fan no longer works
Take the case off and you can replace it as they are fairly standard. Depending on how long ago the fan stopped working, it may have burnt out the unit itself as they need cooling.
Nov 04, 2015 | Computers & Internet
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
Remote doesnt work anymore
Fan remote stopped working. New battery installed.
Apr 14, 2013 | Lakewood HV 18-c Floor / Box Fan
My toshiba HDD protection for windows 7 laptop #P755-S5278 not giving me details like...fan speed,temp,etc any longer...I useto get a pop up box with these details I cant sem to get thos pop up box any...
Be careful of the OS updates you install on your pc, sometimes they can cause these programs from running by stopping cerain services. Launch task manager and see if this service is stopped.
Jul 28, 2017 | TOSHIBA HDD Protection - Shock Sensor...
Fan stopped working
The bearings may have gone out in the fan. Try to find an old fridge and swap out the fans.
Oct 13, 2009 | Refrigerators
Satellite A215-S7444 laptop's fan is no longer working. Was working earlier. What do I do to fix it?
If the fan was making a bearing noise and has stopped spinning then the fan needs to be replaced.
The fan may have stopped spinning because it is clogged with dust, if so loosen with a still brush and vacuum to remove the dust.
A faulty fan will cause the CPU to overheat and shutdown the computer and will not start up again until it has cooled down. Continue to ignore this it will eventually cause the CPU to fail.
Sep 11, 2009 | Toshiba Computers & Internet
AUTO FAN MOTOR NOT WORKING
You need to replace the sending unit which is screwed into the block. It connects the ground circuit to the fan at the proper temperature.
Aug 26, 2009 | 1993 Buick LeSabre
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Medium setting no longer functions
Check the connections on the switch or test the switch with a multimeter.
Aug 10, 2006 | Honeywell HFS641P Stand (Pedestal) Fan
Concord Fans PB-1256-EMN GRANDEVILLE Brazillian Bronze Ceiling Logo
19 people viewed this question
Top Concord Fans Dryers Experts
jdthefixer
Tom Chichester
Ken B
Ken B
Are you a Concord Fans Dryer Expert? Answer questions, earn points and help others
