Question about Tracfone Wireless LG 440G
What does message held mean and how do I disable it?
When a call comes into my phone I cannot hear the person calling and a the Message Held appears. How can I fix this problem?
HOW DO I DELETE VOICE MESSAGES WITHOUT LISTENING TO THEM ON IPHONE 4G
I don't believe voice messages are held on your iPhone itself.
Voice Messages are held by the Carrier you are connected with. Usually you dial the voice message service and delete the recorded messages at their end.
I asked my carrier to turn off the Voice Message service because it became a pain to deal with. That way I can see on my iPhone who has called and call them back if I want.
The iPhone is either a 4 or 4S. There is no 4G
4G is currently the fastest network speed that the phone carrier puts out. The previous one was the 3G network.
Cheers
Mar 03, 2015 | Apple iPhone4 4G iPhone 4
Changing passwords on a used D 307.
Try this:
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Dec 24, 2007 | Cell Phones
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
Hi i want to block number to call me ,my phone is nokia 1280
You can not block that number.Your mobile will not support for that.
* You can do one thing.You can add that number to the screened list.
* If you add means your mobile will not ring if that person calls you.
* Their you will see the miss call information.
* If they send you message means it will be stored in the screened message.
* If you want to add that number means you should follow this steps.
* If you have miss call from that number means select that number there you will be having option select that option.
* There scroll over to add to scrn.list select that one.
* Then it will ask do you want to add this number to screened list.
* Select it.
* From now you wont get ring if that person call you.
* Message will be stored in screened message.Select message scroll over to screened message.In that you will find the message.
Thanks for your question.
Jun 27, 2011 | Nokia 1280 Cell Phone
LOOKING FOR A MANUAL FOR lucent 9510 WIRLESS TELPHONE
Hi, Click this link for more data : http://www.vineland.org/tech/phones.pdf Regards, vote please, Jay
Lucent Telephone User's Guide (All Models) For corrections to this document, contact Steve Dantinne at sdantinne@vineland.org or 856.794.6700 x 2350 VoiceMail Welcome to Audix! The first time you use Audix you must record your name and create a password! To Log In: 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 1. The system will ask for your extension number followed by the # sign. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 2. Enter First Time Password # sign. Record Name As you use Audix, your name will be heard by you and other Audix users. Press 1 Speak your name Press 1 when finished Press # to approve Create Password You will be required to enter a new password with a minimum of 5 digits followed by the # sign. The maximum length of a password is 15 digits. Reenter your password for confirmation followed by the # sign. To Create a Personal Greeting This is what callers will hear when they reach your mailbox. Press 3 anytime you wish to do anything concerning your greeting Press 1 to create your greeting Press 1 to indicate the greeting number you are going to record then speak your greeting Press 2 then 3 to replay the greeting Press # to approve Press 1 to activate for all calls **X or **9 to hang up. To Get Messages 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 2. Enter your extension or voicemail number then press #. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 3. Enter your Password then press # You are now Logged in. Press 2 (You will hear the day, date and time the message was left and the length of the message. If the message is from another extension you will also hear the person's name and extension number) This is the header To play the message press 0 To listen to header again Press 2 then Press 3 To listen to message again Press 2 then Press 0 To Delete message Press *D To skip to next message Press # To forward Press 1 then Press 2 (record your comment) Press # when done recording. Enter the extension numbers you are forwarding to followed by #. Press # when done addressing. Press # to send. Call Handling Features Volume Control The volume control button will adjust three items. 1. If you are not using the telephone, it will adjust how loud or how softly the telephone rings. Press the up arrow to make the telephone ring louder. Press the down arrow to make the telephone ring softer. 2. If you are using the handset or receiver, it will adjust the sound of the incoming voice. The up arrow will make the voice louder. The down arrow will soften the voice. 3. If you are using your speakerphone, the volume control will adjust the sound on the speakerphone. The up arrow will make the sound louder. The down arrow will make the sound softer. Each item is independent of the other, depending on the device being used. That it what the volume bar will adjust. Hold The hold feature puts a call on hold until you can return to it. To keep a call on hold while you answer another call or perform another task. Press HOLD. The green light next to held call will blink. To return to the held call Press the call appearance button of the held call. Redial The Redial (or last number dialed), feature automatically redials the last extension or outside number dialed. To redial the last number that you dialed. 1. Press REDIAL. The last number you dialed is automatically redialed. Note: The redialed number can be an outside number, an extension, or a trunk or feature access code. Transfer The Transfer feature allows you to transfer a call from your telephone to another extension or outside number, if allowed. To send the present call to another extension or outside number 1. While on a call, press TRNSFR. (Dial Tone). Present call is put on hold, and the green light next to the held call blinks. You are given a new call appearance. 2. Dial the number to which the call is to be transferred. 3. Remain on the line and announce the call; if the line is busy or if there is no answer, return to the held call by pressing it's call appearance button. 4. Press TRNSFR again. Call is sent to the dialed number. 5. Hang up. ...............
Jan 21, 2011 | Cell Phones
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
E 71 speaker problem
no it has nothing to do with ur problem, did u try to re-install the nokia phone software ??
Aug 26, 2009 | Nokia E71 Smartphone
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
Voice sound has gone on phone (but ringtones and all other sound working).
there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
Jul 02, 2007 | Panasonic G50 Cellular Phone
Tracfone Wireless LG 440G Logo
15 people viewed this question
Top Tracfone Wireless Cell Phones Experts
David Payne
David Payne
ka4iup
ka4iup
Are you a Tracfone Wireless Cell Phone Expert? Answer questions, earn points and help others
