Question about Dryers
I HAVE A WHIRLPOOL OVEN MOD.#RBS305P004 ON THE CONTROL BOARD IT COMES UP EO-F2 WHAT DOES THAT MEAN
THE PRINT OUT SHOWS EO-F2 ON IT
catriver
  • 878 Answers
SOURCE: Control Panel Display Reading
mommaT, the code has to do with the keypad, key held down too long or stuck or shorted keypad. Have someone remove the key pad ribbon cable from the control board and clean the ends with an eraser. If that doesn't do it, you may need a new keypad. Catriver..post back
Posted on May 13, 2007
jsrock516
  • 5911 Answers
SOURCE: EO F2 code
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Posted on Nov 12, 2007
  • 110 Answers
SOURCE: EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Posted on Jun 01, 2008
SOURCE: My oven is not functioning
buy a new stove
Posted on May 15, 2009
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
I have a new Whirlpool Built-in electric wall oven. I just installed it. The read out says EO F2. What does that mean?
EO-F2 means shorted touchpad.
Try pressing the CANCEL button to see if this clears it otherwise you will need a replacement touchpad.
Dec 13, 2010 | Ovens
What does the error code F2 EO mean?
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 21, 2010 | Whirlpool Accubake RF362LXTT Electric...
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
Shows EO-F2-CODE
F2 means something is wrong with the keypad. Check that the keypad is firmly connected with the control board and press Cancel. If you get the code after a minute, replace the keypad.
Sep 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
EO F2 code
Jun 01, 2008 | Kitchen Ranges
Dryers Logo
Top Dryers Experts
