Question about Connecticut Electric Electrical Supplies
Horizon bq 240
Manual electric
I wish to take the Ellure Plus machine to India where the power supply is 240 volt. What shall I do? What is the power requirement in Watts for this machine. Your feedback is highly appreciated.
You will need to check with the instruction manual of your machine what the specifications are.
Today the 120 volt mains, I am told, is almost a thing of the past and 220 volt is much more common. The UK mains electricity used to be 250 volts but it has been lowered to 240 and eventually it will be lowered to 230 volts to bring us closer to the European specification.
Because most electrical equipment is imported and we are a minority market, electrical manafacturers didn't want to produce specail goods just for us and so for 20 years or so most of our electrical goods are suitable for use in a range of mains voltages from 220 to 240. Sometimes they are marked as such and sometimes marked as 230 volts but we are told 240 won't damage them and they will still work efficiently at 220. It is only very old electrical equipment made for 250 volts that seems slightly less efficient.
Some equipment is made for universal use and will accept 120 volt mains as well as the 220 to 240 range. In this case there is usually a provision to select a different voltage by means of a switch or by changing some simple internal wiring connections. Details of how to do this is invariably printed in the manual.
Equipment produced for 110/120 volts only would become dangerous and be soon destroyed if plugged directly into a 240 volt mains but a transformer can easily be obtained to allow 120 volt equipment to be used on 220/240 volt mains. A great many professional tools are still produced to use 120 volt electricity for reasons of safety and so auto-transformers of all sizes are commonly available and not too expensive.
I have a fairly limited experience of sewing machines but I think a domestic machine has only a very small appetite for power and a supply suitable for a reading lamp will be more than adequate. The exact wattage of your machine will be found in the instruction manual.
Apr 10, 2016 | Sewing Machines
FOSSIL MANUAL FOR BQ-9232
Google (fossil)(BQ-9232)(manual) without parens.
Feb 28, 2015 | Fossil Watches
Boston acountic horizon duo, how do I open it, It was connected to a 240 V and after that it stopped working. I thinking of opening it and fixing the power supply component.
hi i'm looking for that solution too but found by myself you just need to remove the 2 front speaker grille just pull off and after remove the eight rubber that retained the grille the screws is under these rubbers and after gently pry the front cabinet
Nov 13, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
When specs say circuit requirement is 40, do they mean the breaker size?
What are you wiring?
Does it seem realistic that you need 40 Amp capacity?
40 Amp circuit breaker is usually 240 Volt and it goes to heat pump, double oven, or some heavy equipment. 40 amp breaker uses 8 gauge wire.
You can figure a circuit with the formula V x A = Watt
If your VA is 7500 Watts and voltage is 240, then Amps is 31.25
Oct 13, 2010 | Siemens /ite Bq Circuit Breaker Bq3b090 3p...
I need an operating manual for a Standard Horizon CP155c chartplotter
please call Standard Horizon Marine Support 800-767-2450 and they will email you the manual.
marinetech@vxstdusa. com
Sep 10, 2010 | Standard Horizon CP155C GPS Receiver
What does bq mean
BQ means it's a bolt-on type circuit breaker.
Apr 09, 2010 | Siemens /ite Bq Circuit Breaker Bq3b090 3p...
Electrical Supplies Logo
48 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
Steve
hellics
Level 1 Expert
Gene Haynes
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
