Question about JVC Gps Antenna Kw-nx7000, Kwnx7000 For Jvc Dvd 7000
KW-NSX700 add on GPS antenna
Do you need a GPS antenna on a KW-NSX700
GPS antenna error
Unfortunately I have now solution. But since misery love company, take comfort that I'm experiencing exactly the same problem, even after the software update.
Feb 01, 2014 | JVC KW-NT700 7-inch Navigation Receiver...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
JVC Kw-nt3hdt - Clock resets each time car is shut off.
Hi... I have a JVC nt3hdt.. and I was having the same issue... all the wires was connected properly... but because I didn't have the GPS antenna hooked up it couldn't reach any sattelite to maintain de clock... once I received my GPS antenna, I plugged it in, the clock maintained itself pretty good!
Hope it helps,
Oct 19, 2012 | JVC Kw-nt3hdt Cd/dvd/hd Radio/navigation...
Last year I got this device and after 1 & half year my device is not working & showing check gps antenna. Can u please give me a solution Javaid
Probably the gps antenna is not working due to rusty (water inside it). Check the antenna disassembling it. Third part antenna for the NT1 is not available due to proprietary connector so you must buy a (expensive) genuine new one from JVC. Sometimes it's possible repair the old one.
Apr 21, 2011 | JVC KW-NT1 Car GPS Receiver
Sat Nav not picking up a signal will a new antenna fix it?
try a stronger antenna clouds in the sky can affect your signal too make sure the antenna is not blocked bye anything
Feb 11, 2011 | JVC Gps Antenna Kw-nx7000, Kwnx7000 For...
WILL A JVC KW-NT1 FIT IN MY 04 CHEV. MONTE CARLO?
If the vehicle can take double-din radio, it can be mounted.
You need to buy harness adapters.
Sep 16, 2009 | JVC KW-NT1 Car GPS Receiver
Signal lost...system doesn't kick in for about 10 minutes
possibly a low or failing battery, You might want to also add an external antenna. Might i suggest the 50Db Skymaster from Marbella Australia, so change battery and check and invest in the antenna from marbella aust
Jun 30, 2009 | Tomtom GO 300 GPS Receiver
GPS OFF
You will get this if the antenna is closed. Open the antenna, let it do a satellite lock and try it again.
Sep 04, 2008 | GPS
Internal antenna
mine does the same thing....i even have the external add on antenna, mine turns on fine but as soon as you flip the antenna up on the back, the screen starts flashing and the system keeps rebooting over and over again...
May 11, 2008 | Garmin iQue 3600 GPS Receiver
Poor satellite reception
the cheap way to fix it is to make an extended antenna
if you look in the back youll see a gold circle that is made to add an external antenna. now get some foil twist a small strand and push it in the back of the nuvi untill it hits the gold ring. just add some scotch tape to hold it and it should be good
Oct 20, 2007 | Garmin Nuvi 660 GPS Receiver
JVC Gps Antenna Kw-nx7000, Kwnx7000 For Jvc Dvd 7000 Logo
54 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
