Question about Compaq Presario 5000 PC Desktop
Dvd rom won't work
My dvd rom won't work like the computer doesnt read that there is a dvd in the drive it says there isn't,here are the steps the troubleshoot told me to take
  • Make sure the optical drive appears in BIOS Setup screen. The BIOS (Basic Input/Output System) needs to be able to detect the drive before Windows can detect it. To check the BIOS Setup:
    1. Restart the PC and as soon as the first logo screen appears, press the F1 key.
    2. When the BIOS Setup screen appears, use the arrow keys to go to the Main menu, if not already selected.
    3. Check for the hardware-identifying name for the optical drive next to Secondary Master, Secondary Slave, or Primary Slave.
    4. If the name of the optical drive does not appear, check the cable connections for the drive.
  • Remove Digital Audio and DMA capabilities for the optical drive. Digital Audio and DMA are different ways that a CD or DVD drive handle data. Some optical drives may not know how to use these functions. To disable Digital Auto and DMA:
    1. Click Start, and then right-click My Computer.
    2. Click Properties and then click the Hardware tab.
    3. Click the Device Manager button.
    4. Click the + (plus) sign next to DVD/CD-ROM.
    5. Double-click the drive name to open the Properties window.
    6. Click the Properties tab.
    7. Remove the check mark from Enable digital CD audio for this CD-ROM device, and then click OK.
    8. Close all open windows and restart the PC.
  • 749 Answers
You forgot to check the jumper settings of the Hard Disk and the DVD Drive found at the back near the IDE and power cables. If you are using one IDE cable, then one jumper should be a Master, that's the Harddisk, and the DVD drive a Slave. If you are using two IDE cable then both must be Master.
You should check also the Harddisk jumper help settings printed on them, some harddisk needs the jumper settings for Slave presence on the same IDE cable.
If it doesn't work then It's either the cable or the DVD drive has a problem.
Posted on Oct 31, 2007
My HP Compaq 2035 Desktop won't read my sims 2 double deluxe PC-DVD ROM Sowftware. It makes the noise as if it were reading it, but nothing pops up. I have cleaned it, restarted my cp, and went t
Does the computer read other dvds? If it doesn't, then the optical drive probably has a problem with the lens tracking. This could be repaired but isn't worth it. A new SATA DVD writer can be purchased for less than $30. (Or you can get an external DVD drive (with a USB connection).)
I hope this helps.
Sep 20, 2012 | Computers & Internet
I own eMachine Notebook e525 and it won't read any disks. I have tried multiple disks such as music cds, installation cds and video dvds. None of them read or open. There isn't even an icon for the...
> there is no icon for the CD-drive
Probably means that either:
* no electrical power is reaching the CD-ROM drive
* no "data" is being transferred to/from the drive
* the electronics inside the CD-ROM drive have "died"
Check the "power" and "data" connectors.
If necessary, replace the drive with a new CD/DVD reader/writer.
Jun 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
My dvd rom doesnt work. it doesnt read any disc.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 19, 2011 | Computers & Internet
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
My cd rom used to work perfectly.sudenly stoped.the icon doesnt come up in My Computer and doesnt read any cd help please!
According to your issue as you are not able to work with your cd rom and as you have not mention what operating system you are using if its windows then its known issue from Microsoft so try the following website it will help you up in case of windows computers
Oct 19, 2009 | Acer Benq 16x DVD and 40x CD-ROM Internal...
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
My Computer does not read DVD ROM Drive. Any Ideas on how to solve it?
Remove and resintall the power and data cable which conncects the DVD ROM. Try different CDs. If it still doesnt work, the lens must have be at fault.
May 03, 2009 | HP Compaq DVD Drive
My cd rom/dvd drive will not read any disc
Check the cd-rom power is on or not. Then also if its not reading then Insert an DVD/CD cleaner disk and follow the steps. The cleaner disk is available in any of the computer shops. There may be some lens problem. After trying above steps if again same problem occurs then you need to replace the cd/dvd rom drive. Thank you.........
Sep 14, 2008 | Sonic Computers & Internet
DVDRW will not read CDs
1)right clik on my computer
go to
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
