Question about APC Heating & Cooling
Leaking water from ptc ac unit in front .vents all open
Front leaking water all holes open
Make sure unit is has slight fall toward outside.
Posted on Jun 15, 2009
Water leaking around screw of ac vent in bedroom. it is a slow drip that is constant even when the ac shuts off
From what you described, it sounds like the drain hole in the condensation pan under the unit is clogged. Also, the unit may not be titled down enough at the rear of the unit. Generally, 1/4" to 1/2" is required, so that the water in the condensation pan will flow to the rear of the unit, where the drain hole is. These 2 things are where you need to start troubleshooting.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Heating & Cooling
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Aug 08, 2010 | Heating & Cooling
Leaking water in the freezer side from the vent at the bottom
ur drain is clogged. defrost unit and open panel from freezer and unclogg hole
Feb 09, 2010 | Refrigerators
LG LWHD8000RY6 water leak -- gathers inside on the bottom and by the radiator
This may be due to two things, unclean unit, glugged drain holes…an easy way to do this is to pull the front vent off and see inside and see if you can caulk all around the inside and seal up the front by the vent so the water is forced out the front vent [you need to drill a little hole in the lower section of that front vent after you clean the unit and caulk the inside]
Look to see if the drain holes are clear and the water coming out from them either from the back or the bottom…I am not sure how much work you need to do but you may think about installing a hose to it to drain the water out better than the small hole in the back or front…make sure that the unit is little tilted to the side that you have the vent hole at…
This unit discharge lots of water during heat humidity, etc. or dirt built up on the condensing unit on the back, so cleaning may be with vacuum, water pressure, or just by hand, it is up to you… let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 11, 2009 | LG Heating & Cooling
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
I have an amana ac unit that is leaking water out of a hole that is right beside the drain pipe. i cleaned the drain pan out and made sure the drain pipe was cleared out.water starts coming out when the ac...
check filter or coil plugged if drain is clean or there is no vent so the fan holds the water while running then when fan shuts off it lets it go
Jun 21, 2009 | Heating & Cooling
Frigidare thru-wall AC drips water when unit is on.
Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
89 people viewed this question
Top APC Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you an APC Heating and Cooling Expert? Answer questions, earn points and help others
