Question about Samsung Full Option Side-by-Side Refrigerator SR-S27FTA
SR-S27FTA not freezing
Hi. I have rust on my sr-s27fta Samsung refrigerator and I'm trying to take down the door in order to fix it. Do you know how can I do that?? Thank you
There's a plastic cover on the top door hinge. Pop it off and remove the screws that fasten it to the top of the fridge. Pull it off and don't loose the washers on the hinge pin. Lift the door up off the lower hinge pin. If it's the freezer door, do the same but take off the lower toe guard grille to expose the water tube going to the water dispenser. Separate the hose at the in line connector at the bottom of the door before you lift the door up and off the hinge pin.
Mar 25, 2016 | Samsung Refrigerators
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Fridge side is not getting cold getting cold
When your refrigerator isn't cooling properly, the problem could be as simple as a blocked vent, the thermostat was bumped, or a more complicated problem that requires professional service, such as a coolant leak or a bad compressor.
Check out this article, Refrigerator not cooling, for a simple troubleshooting checklist of possible reasons why it's not cooling as well as some suggestions for things you can do. I hope that helps!
Aug 02, 2012 | Samsung Full Option Side-by-Side...
Manual user sr 5070 samsung
My freeze sr 5070 is not cooling .how to check.
Jul 29, 2011 | Swan SR5070 (4.27 cu. ft.) Refrigerator
My refrigerator samsung is not cooling normaly please tell me normal temperature ??? I lost papers intrucions thz
First thing to check is the evaporator coil on your fridge. If it has alot of dust and build up on it, it will not cool properly. Take the front grill off the bottom of the fridge and check your coil. If it's really dirty, use a vacuum with a hose on it to clean. You can also use an old paint brush to remove build up.
May 08, 2011 | Samsung Full Option Side-by-Side...
Freezer does not work but light is on and refridgerator works
check for the coils froven up with ice there is a circuit board on the very back of the unit that you can take and pull off and reconnect the wires that go to it . some times that cures the problem (bad connection)
Apr 07, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezing at any tempeture
I ordered a new thermostat (about $40 with shipping) & installed it. It's pretty easy to replace. The fridge has been working fine since.
Jan 14, 2009 | Sanyo SR-4910M Compact Refrigerator
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
