Question about Philips PD9012P/37 9 Dual Widescreen Portable DVD Player
Won't play disc
Won't read disc
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Tv won't read disc that have been played in it before
If you get a cannot read disc etc either you have a dirty or a bad optical pickup unit in the player--it reads the disc etc.
If bad cheaper to buy a new unit.
Jun 14, 2012 | Disney DTD1363-CAR 13" TV/DVD
Won't PLAY ANY DISC DVD PHILIPS model- dvp3126/98
Dirty or bad optical pickup in the player----bad: cheaper to buy another than replace the part.
Apr 17, 2012 | Televison & Video
Samsung htz310 reads NO DISC
probebly a bad laser. sometimes they will play music but not dvds or even the other way around. from what iv read this is happening to people in just a few weeks.
Nov 19, 2011 | Televison & Video
My samsung bdp 2550 won't play disc took disc to another player and played fine
take it apart and very carfully use a dry Q-tip and clean the lens should read disk after that
Oct 22, 2011 | Samsung Televison & Video
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
Game won,t read was playing game it lend over and scratched it won,t read it now
You will either have to Fix the scratch somehow or buy a completely new disc.
Aug 13, 2010 | Microsoft Xbox 360 Console
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Philips PD9012P/37 9 Dual Widescreen Portable DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
