Question about Asko T701 Electric Dryer
MOD T700 ASKO DRYER REPLACED DRUM ROLLERS PUT BACK TOGETHER WILL NOT TURN ON
When I took the back off my Asko to clean it out I had to lay it on its face to get the drum to line up again with the back - in the doing this a wire pulled off its setting. Did not figure this out until I took the top off the dryer and found the loose wire. I have no idea if this is your problem but it was very frustrating. There is also a black reset button on the back of the dryer that you might try.
Posted on Jun 21, 2009
How to Replace the belt for a Asko T700 Dryer?
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
May 10, 2012 | Asko T700 Electric Commercial Dryer
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
Feb 12, 2011 | Asko T700 Electric Commercial Dryer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
How do I get at the rollers in an Asco T700 electric dryer? Thanks Roger A
Loosen backplate, dismount the drum, then you will get acsess the rollers. some work, but you'll get there.
Jul 17, 2009 | Asko Dryers
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T701 Electric Dryer Logo
251 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
