Question about Samsung HLN617W 61" Rear Projection HDTV
Same noise whining noise
Same noise
  • Samsung Master
  • 5,138 Answers
ReplACE YOUR COLOR WHEEL
Posted on Jun 15, 2009
Ac makes whining noise on a 2004 Pontiac grand prix
Is the whining noise coming from the engine compartment where the compressor is located or is the noise coming from inside the car? If the noise if coming from inside the car it could be your blower. When a blower wears down the bushing is the first thing to wear down and it begins to have play. That makes the blower/fan vibrate making a loud whining noise. Replacing the blower could solve that whining noise.
If the noise if coming from the AC compressor, it also could be a bad bearing within the compressor.
Feb 23, 2015 | Pontiac Cars & Trucks
2006 Toyota Camery Whining noise when idle and gets louder when accelerate
Open the hood. Listen for where the noise is coming from. Fix the thing that is making the noise.
Jul 18, 2014 | 2006 Toyota Camry
Every time I press my gas in my car I hear this whining Noise and I'm trying to see what it is that whining noise
does the noise sound like its coming from your speakers? if so and if it gets louder with engine rpm it is called RFI (radio frequency interference) its coming from your alternator and being picked up by your radio and coming through your antenna. hope this helps.
,Vinny
Feb 25, 2013 | Cars & Trucks
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
I have a whining sound coming from the transmission. No slippage, drives great
Possible low on fluid will make uniquik whine noise,But another common whine noise is fron serp belt idler pulley,noise will increase with speed.
Jun 17, 2009 | 2002 Oldsmobile Aurora
Whine noise
Does occur in certain conditions? Like when the Air Conditioning is on? Check the a/c compressor if so.
Jun 02, 2017 | 2001 Ford Mustang
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Samsung HLN617W 61" Rear Projection HDTV Logo
87 people viewed this question
Jerry Greenberg
Jerry Greenberg
