Question about Apple Mac mini G4 Desktop
What do I need to connect two 8 ohms speakers to my Mac Mini?
External speakers vs. earphones
    Top Expert:
  • Apple Master
  • 14,162 Answers
Posted on Feb 24, 2016
My speakers is100 watts which stk I'm going to us for the my radio and it's two speakers each one is 100 watts my radio is Sony TA-V715
The watts of the speakers are not too important when connecting to an amp. With large wattage speakers such as yours the amp will drive them. What you only need to worry about is someone turning the volume up to much, but only if the Sony amp can deliver a greater wattage than the speakers. If it can it will destroy the speakers at the highest levels.
However when connecting speakers to any amp, you must look at the Ohms of the two items. You must NEVER connect a speaker of lower Ohms to an amp of higher Ohms than it. Must amps and speakers will fall between 4 to 16 Ohms. If your amp says 4 ohms you can connect just about speaker to it. But if says 8 Ohms, you must not connect any speaker rated lower than 8 Ohms. Connecting a 4 Ohm speaker to an 8 Ohm amp will destroy the output transistors of the amp.
Nov 05, 2016 | Sony Audio Players & Recorders
How can I connect extra speakers to my BXL 1800 ultrabass
IF You don't have a separate external input jack. then you need to determine the overall impedance (ohm alottment ). so it will read something like 6, 8, or 16 ohm max. at that point look to see what your speaker output reads.(should be a plate on the speaker) if not, then disconnect speaker and put an ohm meter on it . it will give you a resistance reading , that is your ohms. so toadd a speaker, you must maintain not to exceed the rating. in hooking up. you can do it one of two ways. the first method woukld be , from the amp go positive to pos. side of speaker, and from the speaker neg. sid, go to the pos side of the speaker your adding . from the neg. side of that speaker go back to neg. side of amp. ( rthat is known as a series hook up. this doubles the ohm output of the two speakers ) - turns 4 ohms into 8, 8 into 16, etc. the other way is known as parallel. (from the amp take the pos.side and make a "y" and send those leads to each appropriate speaker. positive to positive. and do the same with the negatives. *this cuts your ohms in half. 4 int o 2, 8 into 4, etc. = hope that helps
Apr 05, 2014 | Music
4-8 ohm output
it is load resistance. set the amplifier switch to the resistance ( X amount ohms) to match your speakers. Although running 4 ohm speakers at the 8 ohm setting is louder, it will hurt your amp
most home/semi pro speakers are 8 ohm, while car speakers are 4 ohm. If you are doing a multi speaker pa/intercom install use your formula to calculate total load is 2 8 ohm speakers in parallel are four ohms . express them as fractions and add the denominator ie:8/1 +8/1 = 8/2 or 4/1 or 4. now connect that in series (add the top numbers)with another 2 speakers in parallel and you get back to 8 ohm load. repeat the same process over and over and you can hook up to 32 speakers to the amp without needing the 70 volt tap. hope this helped.
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
Trying to connect 4 dual boss 12 to a 5500 boss class d amp
You can only connect an amp which has an output of 8 ohms to speakers that are 8 ohms are greater. You must NOT connect to speakers less than 8 ohms.
If the amp is 4 ohms you can connect speakers of 4 ohms or greater.
If the amp says 4 to 16 ohms then you can't go lower than 4 ohms.
As long as you stick to that rule the choice of speakers is up to you.
Mar 02, 2014 | Numark TTi USB Turntable With BuiltIn...
External speakers are working but headphones/earphones are not working on my computer
Maybe the headphone connector is broken. If that is correct you need to replace the motherboard. If you had connected the earphone and accidentally received a tug on the cable perhaps the earphone connector was damage.
Nov 18, 2010 | Computers & Internet
No sound from speakers
Probably.
Do they connect to the computer via USB or mini plug?
If mini plug, make sure you have the right jack on the back of the computer (there's two)
Then go into System Preferences ... select "Sound" and see if you can select something other than "Internal Speakers" - the computer may just not be aware that you want to use the external speakers ...
Are the speakers powered? Is there a volume control on the subwoofer, or an external fob with a volume control on it? You probably know this if you used them previously with your Compaq computer ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 11, 2010 | HP JBL Platinum Computer Speakers
How can I connect external speakers to my Vizio VA26LHDTV10T?
Used the earphone plug with amplified speakers.
Dec 24, 2009 | Televison & Video
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Low Volume from headphone jack...
I do not think that this TV does not have a separate circuitry with its volume control for the earphone. If your earphone is mono, are you using a plug that is mono to connect the speaker?
Try using AWG 20 if you could to see if that helps.
Good Luck.
Jul 24, 2008 | Durabrand DWT2405 24" TV
Apple Mac mini G4 Desktop Logo
316 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
