Question about Dometic A&E 8500 20 Awning W/ Polar White Vinyl Weathershield
A&e weather pro awning only clicks and will not work. It is not the motor.
Motor clicks does not work. could it be the wind sensor
The awning manufacturer for rv
You can go to RV awning manufacturers or to marine awning makers. They all use the same material. Also a Chinese company listed below.
  • RV Awnings Online - RV Awnings, Awning Parts and ... www.rvawningsonline.com Representing Carefree RV awnings, parts and accessories for over 10 years. Order online or call 800-780-8677. - Scotties Canvas, in business for over 50 years.
  • Rv Awning Manufacturers, Rv Awning ... - alibaba.com www.alibaba.com > ... > rv awning > rv awning manufacturers Rv Awning Manufacturers, Wholesale Various High Quality Rv Awning Manufacturers Products from Global Rv Awning Manufacturers Suppliers and Rv Awning Manufacturers ...
  • RV Superstore Canada. Awnings & Covers rvsuperstorecanada.ca/awnings-covers Shop by manufacturer. A-1 SECURITY; ADAMS MANUFA; ... Awnings & Covers; Slide Out and Window Covers ... Awning Accessories
  • RV Awnings, Patio Awnings & More - Carefree of Colorado www.carefreeofcolorado.com Carefree of Colorado develops, manufactures, ... Fifth Wheel or Toy Hauler, we have a HUGE selection of awnings and RV accessories to outfit your rig!
  • China Rv Awnings, Rv Awnings Manufacturers, Suppliers ... www.made-in-china.com/.../hot-china-products/Rv_Awnings.html China Rv Awnings - Select high quality Rv Awnings products varied in Style, Operation Method and Frame Material from certified Chinese Pvc Tent factory, Frame Tent ...
  • RV Awning Manufacturer - LoveToKnow camping.lovetoknow.com/RV_Awning_Manufacturer Once you buy your RV awning, the next thing you have to think about is how you are going to install it. While it is possible to attach it yourself, it can be ...
  • China Rv Awning, Rv Awning Manufacturers, Suppliers ' Made ... www.made-in-china.com/products-search/hot-china-products/Rv_Awning... China Rv Awning - Select high quality Rv Awning products varied in Style, Operation Method and Frame Material from certified Chinese Pvc Tent factory, Event Tent ...
  • Luxury RV Awnings - Girard RV Awnings - Girard Systems https://www.girardrv.com All our girard product designs and innovations greatly improve the aesthetics for awnings and ... The reason why more RV manufacturers and RV owners choose Girard ...
  • http://www.bing.com/search?q=rv+awning+manufacturers&qs=SC&pq=rv+awning+manufacturer+&sc=2-23&sp=1&cvid=8F5A4EBCFB8E47908A2DD6EFE172B072&FORM=QBRE
    Jul 10, 2016 | RVs
    Why does 15 amp awning fuse keep blowing?
    find the dead short
    could be a failed awning motor , cut lead , faulty inside light sockets or wiring to the sockets
    Feb 17, 2016 | Cruiser RV 2015 Shadow Cruiser S-282BHS
    Oregon Scientific WMR86A wind sensor does not communicate to the base station. It is a new device, first time assembled.
    I believe the wind sensor is a rotating cuff that has a wire which needs to input into the main reader or the wifi unit.if it's the wifi unit you need to check the receiver is picking up the signal.if it's the main readout then check the connection.if it is wireless, you may find a switch on the transmitter to change channel.this may fix the problem, especially if the receiver is near other wireless or bluetooth equipment.
    Feb 19, 2015 | Oregon Scientific WMR86A Backyard Pro...
    Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
    There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
    Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
    Motor Home Door Awning
    When you press the operation switch do you hear the motor clicking or trying to operate? If not you need to determine if you have power going to and through the operation switch. These motors usually have an inline circuit breaker that will need to be located. Some of the circuit breakers automatically reset themselves and some have a small button on the side that will pop out when tripped. Once you determine that you have power to the motor and it still does not work then you more than like have a bad motor and will need to manually override the motor to bring the awning in. The awning should have a manual crank that will allow you to connect to the center eye of the operating gear and manually close the awning. I have attached the installation and operating instructions for your awning. http://67.238.126.140/pdf/3307901.011.pdf
    Apr 14, 2014 | Dometic 975CQ Elite Oasis II Power Door...
    Awning retracts at random
    some awnings have a sensor that retracts the awning if wind elevates to certain level. i wish mine did. i have seen them ripped off rv's.
    Jan 19, 2014 | Dometic Heating & Cooling
    What is motorized awning?
    motorized awning feature sensors that cause them to automatically deploy when it's sunny or rainy and retract when it's windy to prevent damage, rather than doing it manually every time.
    Sep 02, 2012 | Alpine Garden
    Power awning blows fuses when trying to extend
    Hello. It sounds like you've got a short or a bad ground somewhere in the circuit that runs your awning. Could be a loose wire, a bare wire or damaged wire touching a ground or another damaged wire. Could also be in the motor (little DC motor somewhere I'm assuming) it may have seized or the windings gone bad and instead of working at taking up the electrical load, the load just shoots across it, which is dangerous hence the fuse blowing. Tracking down where a short could be is really a pain which is why it will be an expensive fix if you bring it somewhere. If you have the patience and some kind of multimeter, digital or analog, (you can pick one up cheap at any hardware store) you don't need the really fancy ones. A $5-$10 analog meter with a battery is sufficient. Then you've got to start from where the fuse is and work your way back towards where the power is coming from checking for faults (open) areas. Do this by putting the meter to the Ohms setting. Touch the leads together and the meter should shoot across to the other side. That's a short that you created by touching the leads together. Poking around you will want to look for the same result somewhere in the circuit starting at the fuse ending at the motor that drives the awning. It'll take some time but if you like to tinker you'll learn a little more about your jayco and electrical troubleshooting to boot! If none of that makes any sense or you have the money (or maybe even a warranty) bring it to an RV joint that sells Jaycos.
    Jun 24, 2012 | Heating & Cooling
    How many winds on the tension spring for a dometic 9100 series awning for initial setting? I heard 1-2 feet out from coach, wind 13 times is standard
    2 ft away from coach,wall, awning rail etc.
    up to 12ft long awning = 8 turns
    13-14 ft = 9 turns
    15-16 ft = 10 turns
    16.5 - 18ft. = 12 turns
    19 ft-up = 13 turns.
    Be real careful, !!! seen many a finger/hand injured if not experienced.
    May 14, 2010 | Dometic WA3210 Compact Refrigerator
    Have an awning with control panel model no
    I'm not sure why you are asking this question; assuming you have aready looked for a manual winding feature. Some models have a cover plate that must be removed to access the manual wind device, however you will need a winding crank/handle that fits into the wind device. As far as the auto mechanism not working, 1st check to see if the electic is still coming to the unit ( was there any disruption to the electric line or wall work that would make the line be disconnected or the circuit breaker ? If you still have problems, l please return with a more detailed list of what you tried and what is/is not happening..
    Good luck, Macgivor
    Oct 24, 2009 | Kitchen Appliances - Others
    Dometic A&E 8500 20 Awning W/ Polar White Vinyl Weathershield Logo
    396 people viewed this question
    Top Dometic Garden Experts
    Dennis Key
    Dennis Key
    john h
    Are you a Dometic Garden Expert? Answer questions, earn points and help others
