Question about LG LRE30453ST (Electric) Stainless Steel Range
Temperature Control Oven burns everything regardless of temp setting. Adjusted thermostat to -35, worked fine once now back to original problem
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Dec 02, 2014 | Hotpoint RGB745 Gas Kitchen Range
Tip
Electric stove oven burning food?
if your oven is over cooking and or burning everything ,more than likely its your temp.thermostat it is not that hard to replace,before you do that go down to your nearest home depot or lowes or appliance store and get a portable thermostat they usually crome in color,take and set your oven to a temp like 350 for example put your new t.stat inside your oven and keep checkin to make sure it dont go above 350 if it does then you will need to replace the thermostat.to get to it first pull the t.stat knob off remember its the one you set the oven temp.with unplug range pull stove out away from wall so you can get behind it,you will have to take off all the screws that hold your cover panel on the screws are usually 5/16 nut driver.take the two screws off the front right behind where the temp knob is,mark the wires so that you do not forget where they go,, you dont want to hook them up wrong.it can cause alot more problems if they are put on wrong ok now,open oven door and you will see on the inside of the oven a copper wire that goes from the temp.control to inside your ovenall you have to do is take the wire and feed it through the back pull it out and take to your nearest appliance store make sure you write the model number and brand of the stove pick up the new one and put new one back on, put panel back on plug range in,and set temp back to 350 put the portable thermometer back inside oven should be good to start baking again
on Mar 09, 2010 | Kitchen Ranges
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Oven temperature is inaccurate and takes a long time to heat to proper temp. I have replaced thermostat with no improvement.
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 12, 2011 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I own a spectra range Model # JBP30B0B4WH The problem is that the oven temp, is off about 15 degrees how can I adjust it? Roy
This is from page 13 of your manual:
Put the Oven Temperature knob in
the OFF position.
Press and hold the HOUR +/– pads for
5 seconds until the display changes.
Before display changes back, press
the HOUR +/– pads to increase or
decrease the temperature in 5
degree increments.
The oven temperature can be adjusted as
much as 35°F. or down as much as 35°F.
If the oven adjustment is set cooler
than the factory setting a minus sign (–)
and the adjusted temperature will appear
in the display.
Wait several seconds for the control
to automatically set and return to its
previous setting.
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Erratic oven temperatures adjusted the thermoatat as per instructions in manual no change
if adjustment of the screw behind the oven knob did not help:
replace the oven thermostat the part can be found at: searspartsdirect.com
Sep 05, 2009 | Kenmore Kitchen Ranges
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Wall oven too hot,at 350 setting is almost 400 degrees burns food
I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
Dec 05, 2008 | Frigidaire Kitchen Ranges
LG LRE30453ST (Electric) Stainless Steel Range Logo
35 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
