Question about RTO Sole F80 Treadmill
Incline operation shutter noise when moving
Incline mechanism sounds like it needs lube?
Incline stuck treadmill
Run the software calibration for easy diagnostic and fix it. Lube the incline mechanism. Go to Hood cover motor and follow the steps or read your owner manual.
God bless you
Oct 15, 2013 | Icon Epic T60 Treadmill
We have a Free Motion Tt30 Incline Trainer making a loud noise that sounds like a bearing going bad, then the noise stops. Do you have any repair suggestions?
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Sep 06, 2012 | FreeMotion Tt30 Incline Trainer
Belt stopped
1) lube the deck belt inmediately.
2) lube the rollers bearing too
3) measure the input voltage motor, if there are the motor need repair
4) measure the outputv voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block
God bless you
Jun 28, 2012 | Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
The incline motor makes a noise near (but not at) the lowest elevation when rising or lowering. The noise is somewhat metal-on-metal and only lasts 1 second or less. Is this a concern? Is there anything...
Incline Motor
Treadmill manufactures publish user's guides that contain running deck incline operation procedures and warnings. Typical guides include weight limits and conditions for use. Most treadmills are designed to manage up to 250 pounds of weight. Operating the incline with excessive weight on the deck or cycling through numerous incline setting in succession can tax the incline motor. In time, the normal sound of the incline motor may become louder when the feature is used inappropriately.
Jul 25, 2011 | Nordic Track NordicTrack Treadmill, A2550
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
My camera makes noise when it's turned on, but not while reviewing pictures.
hi!
What you describe sounds perfectly normal! While powering on the camera, it takes out the lens and perhaps doing some mechanical self-tests. All this means moving parts using little servos inside the camera. Same happens when taking pictures - the lens moved, the shutter closes (and reopen), etc...
While watching the pictures you've taken, you're only reading digital info. from the memory cards - no moving parts, no mechanical movements - hence, no noise!
Take care,
Pelu.
Mar 17, 2010 | Kodak EasyShare Z710 Digital Camera
Washer was making a very loud shaking sound in the spin cycle, the noise stopped the spinning stopped and I smelled burning.washer will not spin
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 27, 2010 | Frigidaire Washing Machines
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
RTO Sole F80 Treadmill Logo
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
