Dps-172dp a power problems
How to power on dps-450cb?
http://www.ascendtech.us/delta-dps-450cb-a-450w-power-supply_i_cspdps450cbarps.aspx
Aug 29, 2014 | Apple Xserve Raid Delta Dps-450cb-1 L Rev...
Where is fuse in velodyne dps-12
Just a guess, but the drawing in the manual shows a fuse rating of 2 amps where the power cord enters the box. Is this a combination fuse/connector. Have you looked if the rocker switch accommodates a fuse? Sorry if no help.
Nov 28, 2013 | Velodyne DPS-12 Subwoofer
DPS-312AB-1A diagram
How to check whether the DPS 320-1A HP SMPS is working with out connecting it in to the motherboard
Sep 02, 2013 | Dell (DPS-312AB-1A) (dps312ab1a) 320-Watt...
Pinout diagram for DPS-450FB
Pin configurations are available on the web site. Go to Support and input the data they require. Download the manual and your in business.
Feb 24, 2013 | Gateway 980 / 960 Server Power Supply...
Dell DPS-1200EB A REV :01 I need to know which prong provides 12v power at 100amps. The power supply is from a poweredge 1855 i think. and i want to use it to power my big car amplifier. so i need to...
As an audiophile and former hardware engineer specialized in switching power supplies, this would be the last thing I would do in my life.
Switching power supplies are noisy and when used in a power amp they will deliver horrible sound quality.
Mar 22, 2011 | Dell (DPS-1200EB) (F5323) 1200-Watt Power...
DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Jun 12, 2009 | Westinghouse LTV-32w3 HD Television
Pinouts for DPS 1200 eb a /24 pin
CALL A LOCAL COMPUTER CABLING SPECAILIST AND SEE IF THEY CAN HELP YOU WITH THE PIN OUT
NEED MORE HELP CONTACT ME
CANDYMANGANDY
Jan 28, 2009 | Dell (DPS-1200EB) (F5323) 1200-Watt Power...
Volodyne dps 12
maybe its the amplifier that does not take too much power to the speaker you need to buy a new amplifier and the sound will not cutoff.
May 31, 2008 | Velodyne DPS-12 Subwoofer
Is ther any power suply that i can use instead of my original one
Its physically different shape will probably require you to modify your case to accept a conventional power supply. Just did a quick search and found an Ebay active sale and an on-line store that had your power supply for a reasonable amount. That might be a more reasonable alternative for you. Ebay: http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R10&satitle=power+supply+dps+185db&sacat=3666%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=14850&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp= Other guy: http://affordablesurplus.com/delta-dps-185db-a-power-supply.asp
Dec 06, 2006 | IBM DPS-185DB (DPS185DB) Power Supply
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
