Question about Kenwood Kc-z1 5.1 Home Theater Av Audio Video Control Power Amp Amplifier Tuner
Logitech harmony didnt work with kenwood kcz1 receiver
Need to find a remote to run the kenwood vr-510 receiver
The Logitech Harmony 700 (IR) works great for my Kenwood VR-510 plus my other video components. Got from E-Bay for $144 with 3 yr warranty, around June 2013.
Oct 13, 2011 | Kenwood VR-510 Receiver
Need a remote for it
You can purchase this:
http://www.amazon.com/Logitech-Harmony-300i-Remote-Control/dp/B003IZFCFW/ref=sr_1_11?ie=UTF8&qid=1298870275&sr=8-11
It is a Logitech Harmony 300i remote. You can program it to use with your panasonic receiver, and can retain all functionality, just as if you had the real remote.
Feb 28, 2011 | Panasonic Audio Players & Recorders
Remote don't work it work intermittently.Tried a logitech harmony and it does the same work when it want to. Need help
Since this issue is happening with both the original remote and the Harmony remote, it is more then likely a problem with the IR receiver on your device. If I were you I would call the manufacturer if it is still under warranty. Otherwise, someone on here may know how to fix it.
Apr 30, 2010 | Kenwood VR-507 Receiver
Blank screen on logitech harmony 520 remote
If the firmware didnt help, then it is a hardware issue. You probably got water in the battery compartment or something.
Anyway you should call Logitech support for a warranty claim. Or, you can do it by taking a look at the following link:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12657
Hope I was able to help!
Jan 26, 2010 | Logitech Harmony 520 LCD Remote Control
Volume changes when other buttons are pressed. Randomly the remote drastically changes the volume on the receiver when you press another button.
Hi. Were you able to get this remote working ? I suggest you try a firmware update, since you didnt mention that you had tried that. I find that usually solves weird problems like this one. You can do that by going through the following steps:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote
Hope that helps :)
Dec 18, 2009 | Logitech Harmony 550 Remote Control
Compatible TVs
I can help you with your Logitech Harmony 550 remote control.
The Logitech Harmony 550 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Jun 06, 2009 | Logitech Harmony 550 Remote Advanced...
Cannot get DVD to play movies -
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
Harmony 890 Manual Download
Feb 02, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 670 universal remote
Greetings Hendon,
The close captioning your looking for would have more to do your television or video source then your remote control.
Depending on how you receive your broadcasting you may want to make basic adjustments to your other equipment. If you receive it through your television you should check your television setup menu for something along the lines of "caption", "CC", or "Text". As well if you receive broadcasting through a cable or satellite box their setup menus should have options for similar options.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 01, 2008 | Logitech Harmony 670 LCD Remote Control
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
Kenwood Kc-z1 5.1 Home Theater Av Audio Video Control Power Amp Amplifier Tuner Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
