Question about Garden
Briggs and stratton 6.5 hp 2.500 psi wont give presser constentley
17237kda briggs and Stratton 2.500 psi no pressure
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
I will need your model # to assist further
Posted on Jun 11, 2014
  • 313 Answers
SOURCE: dayton 5000 psi pressure washer
check out www.smallengineadvisor.com for trouble shooting & repair.
Posted on Jun 24, 2008
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
When I check the compression on my 26 hp briggs and Stratton I get 90 psi on one and 120 psi on the other. is this ok or do I need work. I lose power on mower deck start up and thicker grass and up hill
no it is not ok. The low side will have a problem as they should be 120psi. It could be a head gasket but most probably will be incorrect valve adjustment hold a valve slightly open
Aug 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 3000 psi wont start.
did you leave fuel in it for the 30days and how old was the fuel then it is only good for about 30days in small engines
Jun 03, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
