Question about Alpine CDA-9856 CD Player
Need the security code
The battery died and when it was recharged the radio wont turn on. i need the code
Radio stopped after the battery died and was recharged
The first thing to check is the fuse for the radio. More likely, though, is that the radio needs a security code to turn back on. A local dealership may be willing to give you this code if you go there with your title. There also websites that offer radio unlock codes. Does the radio display anything when you start the car or when you try to turn the radio on?
Jan 23, 2013 | 2004 Chrysler Concorde
I disconnected battery and antenna for 2003 acura tl but code wont take
on the TL - 5 digit code for the radio; 4 for navi; numbers are typically on a sticker on the side of the glovebox (nearest radio) or rear truck arm (great security acura?). Need to unplug the antenna and then put in the code, reconnect the antenna and your back in business. search the net to learn how to access the back of the radio. typically needed after power is lost to the vehicle, new battery installed, etc.
Oct 10, 2012 | 2003 Acura 3.2TL
95 xj battery died replaced battery radio comes on displaying wait on screen how do you get the unit to work
The Radio unit may need a 4-6 digit security code. Locate the owners man and other paperwork, (usually in the leather binder for jags) the radio code is in there along with it. No owners man? Call your local Jag dealer and give the parts dept your V.I.N. # . the parts guys will assist you better and wont pressure you to make an appt for service....
Once you get the the code, turn the ignition to the on position-without the engine running, simply enter the digits using the radio station preset #'s..... as soon as the last digit is entered, you'll hear a "beep" sound, indicating the security is deactivated and ready to go... good luck!
Mar 08, 2011 | Car Audio & Video
2007 Honda Odyssey Battery died and when I recharged it my car radio says code and wont start?
Yes your radio need a code and you suppose to have it when you bought the car. So now call your dealer and ask for the code and i think they will ask for your information and your VIN number. Good luck
Dec 19, 2010 | 2007 Honda Odyssey
Battery died. on recharge the radio doesn't turn on. How do I get my radio back on?
I think this radio requires a security code, should have come with vehicle or you can remove it and use the sn# to contact the Dealer and they can provide code ?
Aug 12, 2010 | 2008 Chrysler Aspen
Battery of my car died my radio code needs cracking
you need to have power to the radio on for an hour or two. (ignition switch and radio on).
Mar 10, 2010 | Car Audio & Video
The cars battery died and now i recharged it and the radio is asking for a code whats the code and how do you type it in
that would be the security code that is meant to protect the radio from being stolen. This is usually provided on a plastic card when you buy the car. In case you don't have it, you will have to go in person to your honda place and identify yourself as the owner.
As soon as the power is cut off to the radio (ie, the battery dies or the radio is ripped out of the dashboard) the radio gets locked. This is when you need the code.
Good luck.
Dec 25, 2009 | 1993 Honda Accord
My battery in my 2002 audi s4 died now the radio
probably need a security code to unlock it after the dead battery, check in your owners manual or other paperwork that came with the car the code should be there somewhere. If not you may need to contact your local dealer. Hope this helps
Dec 08, 2009 | 2001 Audi S4
Radio doesn't work after battery died, recharged and later
hi.
find your radio here...http://www.ibiblio.org/tkan/audi/radios/radios.html
then follow link for program instructions
good luck
Mar 27, 2009 | 2002 Audi TT
Alpine CDA-9856 CD Player Logo
24 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
