Question about Dewalt D51844 Framing Nailer
REPLACED ALL O;RINGS ON DW 51844 WILL NOT SHOOT
REPLACED ALL O'RINGS AND S3ALS ON MY DW 51844 , BUT IT WILOL NOT SHOOT A NAIL WHAT IS THE PROBLEM
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Similar "bolt not retracting" problem
Dewalt offers a Oring kit for this tool part #610773-01 for 27.37 and they have instructions on installation. Also you can go to Dewaltservicenet.com and download a schematic for this tool. It has a stuck valve or similar damaged part to cause this. Let me know if you need more assistance
Posted on Jul 02, 2009
SOURCE: My nail gun will shoot one nail and then stop shooting.
check with one of your friends that have a nowinly good 18v bat if that dont work check for little pieces of plastic or pieces of the nail that are jamed up by the plunger
Posted on Apr 22, 2010
puertobori
  • 7733 Answers
SOURCE: Dewalt 51844 framing nail gun, Leaking air out
Go to eReplacementParts.com : Power Tool Parts and Tool Repair and find a diagram and the parts you need.
Posted on Nov 02, 2010
H2_Brad
  • 425 Answers
SOURCE: dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Posted on Aug 25, 2012
Sounds like air leaking inside won't pressure up & shoot
It probably needs servicing. Strip gun & clean it may have water inside from compressor and/or may have too much oil inside (may have no oil at all and be seizing up). Clean & check O rings. ( I replace O rings during a service). When rebuilding apply a little Teflon grease to the O rings and smear a little inside the sleeve, do not add oil at this time. Connect to airline and check for correct operation. If all OK add a couple of drops of oil down air intake before starting work as normal.
Mar 17, 2014 | Stanley Bostitch SB1850BN 18Gauge Brad...
Porter cable repair
Try a set of Orings from the Oringstore online,,,,lots of times the o rings that seal the cylinder to the nailer body decompose
May 17, 2013 | Porter Cable Air Tools & Compressors
Dewalt framing nail gun want shoot nail
Aug 19, 2012 | Dewalt Tools & Hardware - Others
My RN175 shoots you think it shot the nail, but when you move the gun to shoot the next nail the nail you just shot falls out the end of the gun. What could cause this?
The driver is coming down far enough to break the nail off the strip but not far enough to drive it in. This could be caused by any of the following:
- The driver is broken off and too short to drive the nail
- The driver is bent and doesn't travel all the way down
- The seal/o-ring on the piston is damaged and air is leaking past it
Any of the above will require you to remove the head and inspect the driver, piston and o-rings or have a service center check it out.
Mar 07, 2012 | Porter Cable RN175 Roofing Coil Nailer
I have an F60FN Stanley Finish Nail Gun.
did you lubricate the o-rings before reassembly with a dab of grease? also does the tool fire at all, could be a problem with the firing valve. Let me know what you find and I will keep trying to help
Jan 05, 2012 | Stanley Air Tools & Compressors
Bostitch F21PL Nailer: my nailer does not shoot a nail. I oiled it and st...
I don't have a lot to go on here. Can you describe what does happen? Is there any release of air at all? You can try checking the o-rings for leaks. There are o=ring kits available for under $20 that contain all of the o-rings. Also, proper lubrication is required for operation. If the main plunger chamber does not have enough lubrication, the plunger won't move properly and not set the nail.
Please update this with any details you can.
Thanks,
Dan
May 17, 2010 | Stanley Bostitch F21PL Nailer
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Jun 28, 2009 | Dewalt Round Head Framing Nailer D51845
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
Dewalt D51844 Framing Nailer Logo
189 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
