Question about Pentax Q7 Compact Mirrorless Camera w/5-15mm f/2.8-4.5 Zoom Lens
I'm unable to get off of the p mode to utilize the snc mode
I believe I set something I can't get out of
I have bought the Sony SNC-RZ25 camera and my picture is upside down. I thought it was supposed to flip the right way by it self is there something i can do besides mount the camera from the ceiling
The camera was designed to be mounted on the ceiling. Access the camera and open up the settings you are going to want to find a screen like this:
The highlighted area is the selection you will need to enable to flip the picture 180
Apr 21, 2011 | Sony SNC-RZ25P Network Camera
Need default IP address for the SONY SNC-RZ30N
if it's inside your LAN, try 192.168.0.196 or something close to that. If you're trying to access it remotely, you'll need a static IP from your ISP.
Aug 31, 2010 | Sony SNC-RZ30N Network Camera
I can't reach snc RZ30 from external computers
I've never used this model but I would assume the following:
Port forward its IP address/Port using the settings of the router.
More info on that can be found here:
http://www.portforward.com/
Check you IP (www.ipchicken.com)
Use that IP to access remotely.
Hope this helps,
Thanks!
Jan 20, 2010 | Sony SNC-RZ30N Network Camera
Ricoh aficio 1035 factory rest now unable to get into settings
Press the SNC raport and change /set the value default.
Dec 02, 2009 | Ricoh Aficio 1035 Copier
Sony SNC-RZ30N lost connection and preset positions
Have you check switch, in my case the switch has some problems!
Oct 21, 2009 | Sony SNC-RZ30N Network Camera
Failed to connect to SMTP server on Sony SNC-RZ25P
well you need to reset your net work settings under options and than click on network settings and go to reapply
Jul 09, 2009 | Sony SNC-RZ30N Network Camera
Lenovo n500 major issues
For fdisk utility Boot from xp bootable cd,Go to the repair option.In this section you have to mention username & password.Then start Fdisk /f utility.
Apr 13, 2009 | Lenovo 3000 N500 Notebook
EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Stuck in Black and White
configures the day/night or disable
Jul 02, 2008 | Sony SNC-RZ30N Network Camera
Synchronize music subscription error
they want u to snc your songs now to ther sever in this new firmware update u cant go back also once updated firmware unless they offer old verison sumwar eonline u could try but ya new copyrights secuity thing snc your songs to ther website what they want i would try to see online if old fimrware like other ones is outther sumware
Jan 10, 2008 | SanDisk Sansa e260 MP3 Player
Pentax Q7 Compact Mirrorless Camera w/5-15mm f/2.8-4.5 Zoom Lens Logo
12 people viewed this question
Top Pentax Home Security Experts
Lawrence Oravetz
Are you a Pentax Home Security Expert? Answer questions, earn points and help others
