Question about Danby 17 in. DDW1802W Designer Series Built-in Dishwasher
Can i use pool salt for dishwasher salt
Pool salt as substitute for dishwasher salt?
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Tip
Solving Salt Water Pool Problems
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
on Nov 08, 2016 | Pool & Spa
Should i use chemicals with my saltwater system
yes. the saltwater is merely a substitute form of chlorine. you must still balance the water as you would with any pool. you will need to adjust ph, alk, calcium, stabilizer. you also need to check the chlorine level on a regular basis as these systems are either on or off. they dont regulate the amount of chlorine in the water
Jun 28, 2014 | Intex Automatic Salt Water System for ...
How salt to use for start up for a 22 x 52 above ground pool
You need to know how much salt is currently in pool...
then what is total gallons of your pool?
Round pool? 22' round?
52" walls?
Use only Pure Pool Salt, NOT Softener salt!
2700 ppm to 3400 ppm is the range for ideal levels in your pool.
check out this link...
http://www.conelyco.com/images/saltchart.jpg
btw... Your pool, if what I asked above is correct, has 11,400 gallons
May 31, 2012 | Intex Automatic Salt Water System for ...
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Jul 31, 2011 | Intex Automatic Salt Water System for ...
Do you let the salt dissolve before turning on the unit?
Any time you add salt to a pool, you need to turn off the salt system for 24 hours to prevent damage to the salt cell. You can brush the pool to help the salt dissolve if you need to.
Jun 16, 2011 | Intex Automatic Salt Water System for ...
I have a salt water clorinator system can I use softwater salt instead of pool salt when I set up my pool
no you must use a 99% pool salt
The electro cells in a salt generator can not turn anything else into sanitizer ( chlorine )
Jun 21, 2010 | Intex Automatic Salt Water System for ...
How much salt do you add to a 18 x 48 pool
what is the average depth... your going to take your widthxlengthxaverage depth and then multiply by 7.48... thats how many gallons your pool makes up.... most salt chlorinators call for 2700 to 3700 ppm ... get yourself a salt test kit, and make sure you use salt made for swimming pools....
May 24, 2010 | Intex Automatic Salt Water System for ...
Danby 17 in. DDW1802W Designer Series Built-in Dishwasher Logo
188 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
