I get a 10 flah error code when starting the machine
  • 15,935 Answers
F10 indicates the pressure switch isn't sensing a change in the water level.
Unplug the appliance and take the top off.
The pressure switch should be on the left near the top.
Take the thin tube attached to it off.
Blow as hard as you can down the tube for as long as you can.
Give the pressure switch a couple of good taps with your screwdriver handle.
Refit the tube and try the machine again.
Ensure the wiring and plug to the pressure switch are good.
If your hotpoint washing machine is not working and you feel it needs repairs and you are getting the E10 or F10 error code, this means there is NO cold fill and you should check and verify that the taps are on and that the hoses are not kinked.
The first thing to check is the taps, most machines will have the hot and cold fill supply plumbed via a hot and cold inlet valve placed under a sink or directly behind the machine, it is usually a silver valve with the Blue and some times a red flexible hose connected to it, the blue should be cold and if there is a red that will be the hot supply.
In the on position, the plastic switch located on the side of the in let vale should be pointed in the same direction as the arrow on the valve and in the off position it should be pointed across the valve, if it looks off, especially if your valve is under a sink where pots, pans, boxes and other item can get pushed up against it and could turn it off by accident, simply turn it back on, but do not force it, as forcing it could break it, and that could lead to a flood situation.
If the valves looks OK, but the washing machine is still not working and you still get the E10 or F10 error message, you now need to check for a kinks in the pipes, this will probably mean pulling the washing machine out from its housing to continue the repair.
At this stage you need to take in to consideration the fact that the washing machine will be heavy and connected to both the mains electrics and mains water supply and also that putting the machine back properly can often be harder than taking it out.
If you are unsure, you would be best advised to call a engineer, if you are not willing to pull the washing machine out you could still also check any part of the inlet flexible hose pipes that you can easily see, like in the cupboards and also to the side of the washer, if you see any kinks, you could try to remove the kink and test the machine again.
Error codes are usually machine specific and the diagnosis given here is for the hotpoint unit only, do not relate this diagnosis or error code meanings to any other make of washing machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
When I turn my RoadKing on, the turns lights ( both) flah quickly 6 time. I cannot start the engine with the handlebar start button
Sounds like the security alarm on your bike is tripping. You should have a code to enter or you can reset it. I hope this helps.
Jul 03, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
My sony vaio flah drive is i can't format, the
The Flash Drive is already defective. Purchase a new one.
Jul 13, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Yahoo 10 will not install
I also get this error with Yahoo Messenger 10. However it all works fine with version 9.0.
Version 10 is bugged in regards to Windows 7, so there is not much you can do until a patch comes out.
You can download an older version of Yahoo Messenger from here
http://www.oldapps.com/yahoo_messenger.p…
You should also make sure that Adobe Flahs Player is properly installed in Internet Explorer.
You can visit http://www.adobe.com/support/flashplayer with Internet Explorer to install it.
Hope this helps, wbwTeam
Apr 16, 2010 | Yahoo Messenger
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
Cd rom wont start (code 10)
This device cannot start. (Code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Jun 21, 2008 | E-Machines Computers & Internet
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
