Question about Toshiba 42HP95 Television
Toshiba plasma tv 42hp94 works good for 20 to 30 minuts and then the screen starts flikering and the pictures go black. once i put a fan behind it the picutes come back ok and tv works good. what could be the problem? i checked the two bulit in fans and they work fine
  • 6 more comments
  • Anonymous Feb 08, 2008
    i got toshiba 42hp95 lcd work good for 15 to 20 minutes then pictures starts blinking with white horizontal line then blank no pictures at all i heard the sound still working
  • x-tremewire Feb 27, 2008
    Same issue 42hp83, now only works for 5-10min then pixelates then turns black
  • jimmymiller Mar 07, 2008
    Same exact problem
  • Wolfeman2 Apr 08, 2008
    Same problem. Sometimes goes for 4 hours, sometimes 10 minutes. Just the picture goes out. Sound always works. If I unplug power and plug back in, will restore for 15 - 60 minutes. Tried a fan without much success.
  • sunshyne19 Apr 29, 2008
    Look anything like this?(do not delete)
  • Anonymous Jul 06, 2008
    My 42HP95 has worked well for about 16 months. Recently however it works for about 30-45min and then starts to flicker after a few minutes of flicker it eventually just goes black.
  • cronmoN Aug 17, 2008
    I have the exact same problem. Has any one gotten this repaired? Know the cost?
  • Anonymous Mar 29, 2014
    fans seem to run when i check them. Could they be cutting off on there own?
Posted on Aug 17, 2008
My 42hp83 will only stay on for 30 seconds and then turns off. Repair service came to the house today 2/27/08 and said they could do nothing with it. I think I'll get a second opinion.
Posted on Feb 27, 2008
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
Plasma Tv Turning black in areas and speckles red and green as it gets hot.
plz check if the internal cooling fan are in good working condition. avoid keeping magnetic elements..eg.speakers, very nearby.
hope this helps
Thanks for using Fixya
Jul 12, 2008 | LG MU-50PZ90C Television
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
Jul 28, 2008 | Toshiba 42HPX95 42 in. Plasma Television
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Televison & Video Logo
183 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
