Question about InFocus ScreenPlay 4805 Multimedia Projector
Having trouble finding color wheel for Toshiba TDP S25
My light bulb for the projector died and the color wheel cracked into tiny pieces. I bought a new light bulb but now I am searching for the color wheel. Does anyone know where I can find one? I called numerous places and some of them tell me that they don't sell internal parts while others tell me that they do have color wheel but not for my projector model... It just seems I am constantly getting to a dead end. If anyone knows of where I can find this color wheel please reply.
Thank you!
  • 138 Answers
Actually, the toshiba TDP-S25 color wheel only cost USD109
Posted on Mar 10, 2012
    Problem Solver:
  • 4 Answers
Possibly ebay?
Posted on Jun 18, 2009
  • maxxender Jun 18, 2009
    there are multiple broken as is 4805 projectors on ebay as your last resort you could buy one and could take the color wheel from the broken on
    oh i am sorry, i thought you had a infocus screenplay 4805 which is pictured with your question. but none the less the answer works as a last resort if needed.
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Colors look smeared on screen
If the colour wheel on your projector is out of sync, you will get incorrect colours.
If it is out of focus, focus the lens assembly, if misaligned colours, perform a re-convergence procedure at a fully equipped work shop with a qualified Toshiba engineer.
Oct 31, 2017 | Toshiba TDP-T30U Multimedia Projector
Focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Bulb light projects red
Hi there
I guarantee you 100% that this not a bulb problem but rather a Mainboard failure.
This can unfortunately only be resolved by having it repaired or replaced.
And it is expensive incase you were wondering.
Mar 26, 2008 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP D2 Projector
A mirror got loose in the opening from where the bulb sends the light to the "panel" It is blocking part of the light.
I'm not talking about one of the tiny mirrors that makes up the DLP, but there is silver box where the bulb light initially goes. the walls are lined with mirrors whose adhesive fails when exposed to great heat.
I can easily fix it, as i have fixed many of them from this problem.
Dec 10, 2007 | Toshiba TDP D2 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
555 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
