Question about Jerdon Deluxe Lighted Makeup Mirror JGL9W
Change light buls
Can the light bulbs be changed in this unit? And how?
Installed new lamp but her static sounds wd-73733 and still no picture
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
Brake lights want work but all the lights are on changed the buls and the breake swicth
there is a brake light switch behind the brake pedal that may require replacing. There is always a chance you lost the brakes bulbs one at a time as well so check the bulbls themselves
Oct 07, 2012 | 1994 Jeep Grand Cherokee
How to change dashboard cluster lights
you will have to pull the instrument cluster . the buls twist off the back of the cluster you can get bulbs at the dealer
Dec 09, 2010 | 2000 Ford F250 Super Duty Crew Cabs
How can I change the rear license plate lights on a 2007 Accent hatchback? Besides two screws there are also two clips holding the trim piece above the license plate in place.  Unsure if this is the...
there are clips on the side of the bulb holders that squeeze together then push out to reveal the bulb holder. you can locate these by opening the boot lid, and on most mosels removing the plastic surround. you can then see the holders inside. just hold finger and thumb at each end and gently squeeze the clips and push out the holder to replace buls
Mar 12, 2010 | 2007 Hyundai Accent GS Hatchback
I have a fishmate gravity filter - requires 2 8 watt buls and I don't know how to remove the burned out bulbs.
bulbs are in the lid of the unit normally .just undo the srews or seal ect and put new one's in
Aug 25, 2009 | Fish Mate Pond Filter Compact
The left rear light is not working. i can't seem
1 of the buls has 2 fillermint also power all bulbs they weild fillermant and can look ok but are blown
Aug 04, 2009 | 2001 BMW 5 Series
Need to replace headlight bulb
they are replaced from inside the engine compartment... you may have to remove the battery if it's on that side... do not touch the bulb as that will shorten it's life
Robert
Please take a moment to rate this solution... thanks
Jan 09, 2009 | 1997 Pontiac Grand Am
96 DODGE CARAVAN ELectrical
if the buls where replaced and they work and then quit working you need to make sure you are getting the right bulbs because there is bulbs for 6 volt cars and they are very similar.
also make sure to chek the fuses some cars has separate fuses for the rt or lt lights
May 27, 2008 | 1996 Dodge Caravan
NIGHTLIGHT WON'T WORK BUT SURFACE LIGHT WILL
This is a problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 09, 2007 | GE JVM3660 Microwave Oven
Jerdon Deluxe Lighted Makeup Mirror JGL9W Logo
79 people viewed this question
Top Jerdon Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jerdon Health and Beauty Expert? Answer questions, earn points and help others
