Question about Deni Double Burner Hot Plate - 16320
Deni model:16320 burner control switch
Need burner control switch for model 16320
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
I have a 6 burner range top. When I turn on 5 of the six all 6 spark as they should and the correct one lights. When I turn on the left front knob none of them spark and it will not light, but gas does...
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
I hope this helps.
Sep 20, 2013 | Viking 37 in. VGSU161 Gas Cooktop
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have a Whirlpool Gold Accubake Stove with ceramic top ( approx 9 yrs old) ..the dual burner (one size for smaller pots vice versa) will only heat both burners even when you only turn the smallest part of...
This is becoming a common problem. If your dual burners are controlled by the burner switch only, then you need to replace your dual burner infinite switch. Some models have a seperate rocker switch that switches from small burner to both burners. If you have this style then this is usually your problem. Can also be from shorted wiring but this is very unlikely. Good Luck, Appliance Specialists
Dec 11, 2009 | Microwave Ovens
My husband was trying to help clean the controls and broke off the part that holds the control on the cooktop. Can it be replaced? Help . . . need all four burners for Thanksgiving! DCS CT304
You will have to replace the switch if he broke the shaft the knob was on. you can replace the burners just take the burner to your local parts store and show them what you need. on the switch you will need your model number.
Oct 31, 2009 | Cooktops
Burner sparked and now none of the burners work Always had problems with this unit dealer has poor reputation. Early on I had to replace a part on one burner that was covered by warranty dealer denied and...
Either the element or the control panel is most likely faulty. If it is the panel, you may just want to get another oven. You can get the parts and manual from repairclinic.com
Aug 25, 2009 | Amana ACF4225AS Electric Kitchen Range
Deni Double Burner Hot Plate - 16320 Logo
65 people viewed this question
Top Deni Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Deni Kitchen Range Expert? Answer questions, earn points and help others
