Question about Miele H387-1B Electric Single Oven
Door casket Need replacement door sealer or casket
How do you remove the door?
the spring is sprung now and will need to be replaced
Jan 10, 2016 | Ovens
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Where can I obtain a service manual for a Baxter Hematron III sealer?
where can I obtain a services manaul for Baxyer Hematron II Dielectric Sealer
Apr 11, 2013 | Ovens
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Kitchenaid Conv OvenHeating to toast grilled cheese
At higher temperatures, glass expands differently to metal. if glass was installed tightly by what ever means (some use silicon sealer or metal clips etc.) the different expansion rate could have been the problem. Not to mention a possible weakness in that piece of glass.
Sep 14, 2009 | KitchenAid Architect Series KEMC308KSS...
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Oven door
You will need to replace the oven door.
Take the old door out by taking out the 2 to 3 screws on the side of the door. from there you will need to pull the door up and out torwards you. install the new door the same way.
Aug 14, 2008 | Zanussi ZBQ365 Electric Single Oven
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Miele H387-1B Electric Single Oven Logo
18 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
